Results 1 to 20 of 20
    Dec 2015
    Covington, Ga
    Default Any non-dealers in Atlanta area who do oil changes?
    Any non dealers in the Atlanta area do oil changes? Just got a ridiculous quote from local dealer.
    2021 Spyder RT Limited
    Last edited by Peter Aawen; 03-11-2024 at 07:40 AM. Reason: Expanded title to briefly ask the question... ;-)
    Durham,Maine
    How much did you get quoted?
    2012 RTL , Pearl
    Dec 2012
    Murphy, NC
    It is easy to do it yourself and save some money if you are physically able. Also, BajaRon’s shop in Greeneville, TN can do it.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Dec 2015
    Covington, Ga
    $432. I assume 2 hrs labor plus oil kit.
    Does it take 2 hrs?
    Last edited by Peter Aawen; 03-11-2024 at 07:40 AM. Reason: Fixed quote display ;-)
    Durham,Maine
    It is a little high in my book, but not bad if he's doing the whole system, Trans and all. I would do it myself! Or I would try Ron's shop!!!! Top notch people!!
    2012 RTL , Pearl
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by ramblin5 View Post
    Does it take 2 hrs?
    Not in Atlanta Area - so I'm not help to you but for comparison: I'm a hobby mechanic - work on Spyders and Rykers in my spare time - totally different than my Salary Job. I charge $100 for the "labor." That includes a review of the Spyder and the oil change, eyes on brakes, tires, pulley, coolant level, etc.
    The oil change kit is pushing $140 these days. MANY of us don't use the Canam Oil Change Kit. (I will use whatever the customer brings me that I know works well). The setup I use/recommend is closer to $50-60 for the "parts."
    I can do the oil change in less than 45 minutes though I often take my time, do other things while the oil is draining to ensure it gets good and out, etc.
    I can tell you that I'm cheaper than local dealers - which is why I keep a hefty wait list.
    My 2 cents.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    2019 Spyder RT Limited
    2016 F3S , Triple Black
    Dec 2015
    Covington, Ga
    Quote Originally Posted by Jdr00ejr View Post
    My 2 cents.
    You are the kind of guy I'm looking for!
    Thanks for the reply.
    Sep 2016
    Chillicothe, Oh.
    Ask around to other riders that you may know or even ask a stranger you see on a bike. Someone will surely tell you about an independent mechanic or two in that area. I have a good pal that I often help out in his independent shop and he is always booked up. No advertising, just word of mouth.
    2015 RT , Black
    Clinton, MS
    If you have the place and the desire, then for less than the $432 you could get 2 ramps and an oil drain pan from Harbor Freight or Walmart, several filter and 'o' ring kits from Baja Ron, oil, and the needed wrenches.
    2019 RTL Phoenix Orange
    Mar 2021
    Maryland
    My 2 cents.
    Hey I was thinking about doing this around the DMV previously and still have an interest in it due to the wait times at dealerships.
    And even going so far as fabbing up a trailer to do mobile work for oil changes and alignments on request locally and maybe taking it to some events to do work.
    I was just wondering if you have enough work to keep you busy throughout the year?
    2020 F3 SE6
    2020 F3 , Black
    Mar 2015
    Indianapolis, IN
    Quote Originally Posted by CloverHillCrawler View Post
    As I mentioned - it's a hobby gig for me. Between my Day/Salary job, my trips, and my other obligations - I don't get to work on bikes as often as I'd like. I have a FB page for my "business" which was started more as a joke and exploded into this "hobby business" I have now. Wife and I have chatted numerous times about what it would look like as my primary gig but just a pipe dream for now. That said, I don't do much if any advertising (none paid). My waitlist remains around 15-20 almost year round and I say no to a lot of things. People are willing to wait - because to be honest - they are waiting for the more expensive dealers anyway. My challenge is my constantly changing schedule of when I can work - so actually scheduling bikes in has been my achilles heel.
    Joshua
    2012 Victory Vision
    2016 Spyder F3S
    Does it take 2 hrs?
    $432.00..... OMG ..... If you were closer, WE could do it together; your oil & filter - my lift and knowledge. Mike
    Dec 2020
    Down South
    Sorry,
    Have you found a shop yet?
    If you found 1, let me know. I may give them some of my business.
    Otherwise, I may ride up to Tenn and see BajaRon.
    If you went to MMS, they're expensive for all maintenance.
    I like the folks in Cartersville, but they are expensive for some things as well.
    Maybe check out a non Can-Am dealer like WOW or 1 of the Harley spots.
    '20 RT Chalk Metallic
    Dec 2015
    Covington, Ga
    Quote Originally Posted by JohnRuckus View Post
    Sorry,
    Haven't found anyone yet. I don't trust Harley to work on my Harley let alone the Spyder. I'll checkbout WOW. Thanks for the response.
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    I would not use MMS in Marietta based on past experience with their service dept and service advisors.... plus, they are way too high in price. Extreme Propulsion in Cartersville has good service techs, AJ is the Spyder man, and they do alignments too. But it is a bit of a drive to get there from Marietta. I don't think WOW will service the Spyder. However, they are a used dealer and handle all sorts of bikes; 80% Harley, Honda, Yamaha, etc. I have a local friend who was gonna see if they would service his 2014 RT... Answer was a flat - No! .....
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
    Most everything bike related (including the Spyder/Ryker) are seasonal. The farther north, typically, the shorter the season. Around here everything starts to break loose in March (depending on weather). Then runs through August and starts to taper off to very little from November to the end of February. I know of some who do maintenance, installs of our sway bar kits, etc., for very reasonable prices and seem to do very well. But for the OP, nothing that I know of in the Atlanta area though.
    Dec 2020
    Down South
    Quote Originally Posted by WRCLVR View Post
    That sucks. I try not to bad mouth folks/businesses, but I understand your sentiment on MMS. I had unfavorable interactions with sales at 1 location and service at another. I did ride to Cartersville for several services; the laser alignment, installation of floorboard lights, & a few warranty issues too. Maintenance from them is expensive though. There is another place in Gainesville (GMS). I don't have any service experience with them, but a friend bought a Spyder RTL from them a few years ago and didn't have any complaints. Good luck on your search.
    Bossier LoUiSiAna
    Nothing wrong with getting intimate with your spyder & doing some DIY. Ron’s kit, fast delivery to your door. Even if you don’t DIY, it is cheaper than others & worth having on hand.
    Bossier LoUiSiAna
    Update?
    Dec 2015
    Covington, Ga
    Thanks for everyone's responses. I had one of the forum members contact me who does all his own work and offer to do the oil change for me at a nominal fee so I could see how it's done. As we talked and I looked at youtube videos again I was convinced I can do this myself. I have purchased the oil and filter kit and will be doing it soon. I'll let everyone know how it turns out.
    Thanks again.
