Results 1 to 7 of 7
    Dec 2012
    Murphy, NC
    Default RT Oil Change video suggests using a different sized Torx!? - was it wrong?
    I was watching a video on changing oil on a '21 RT. The rider said to use a 45 Torx on the left side and a 40 Torx on the right side. I am currently on my third Spyder and the right-side plug has always been a 6-point Allen key. Was this guy mistaken?
    Last edited by Peter Aawen; 04-03-2024 at 06:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    2020 F3 Ltd
    Spyderpops Bumpskid
    Nov 2015
    Chardon, OH
    Yes, he was mistaken. And that's how drain plugs get stripped out. Clearly a Torx - T45 - and clearly an Allen - 6mm. Otherwise referred to as a hex bit.
    Doug
    ”Freedom is not a loophole”
    Sep 2018
    Australia
    Evil comes in many forms
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by JKMSPYDER View Post
    Yes he is wrong. It may work for him, but sooner or later he is going to have to deal with a stripped-out Allen head (hex key) plug.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Oct 2020
    Vinton, IA
    One of the supporters of this forum sells hex head magnetic oil plugs at a very reasonable price; I recommend a set.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Dec 2012
    Murphy, NC
    Of the three Spyders I have owned I have immediately changed out the OEM plugs to hex head plugs from goldplug.com. Worth the money and headache.
    2020 F3 Ltd
    Spyderpops Bumpskid
    If it was a YouTube video see if you can find it. Add a comment letting viewers know they need to use an Allen wrench.
