Results 1 to 8 of 8
    Jul 2021
    FL
    Default Rear brake pads frustration - any ideas on how to loosen all the Loctite??
    Am I ever frustrated... the amount of Loctite and Florida salty air corrosion made the removal of the bolt that holds the pads impossible.
    I stopped before I rounded it off, what a pain. BRP seems to be obsessed with Loctite everywhere in large amounts, I'll try another day.
    Sorry about the rant... open to suggestions, right now I'm waiting to see if PB Blaster will help... arrgghhh!!
    Last edited by Peter Aawen; 04-04-2024 at 05:20 PM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member VitoNam's Avatar
    Nov 2018
    NW Minnesota
    A bit of heat on the bolt head should make that yellow Loctite loosen.
    Oct 2011
    Kalamazoo, Mi
    Quote Originally Posted by jma57 View Post
    Am I ever frustrated...the amount of Loctite and Florida salty air corrosion made the removal of the bolt that holds the pads impossible.
    Sorry about the rant...open to suggestions, right now I'm waiting to see if PB Blaster will help..arrgghhh!
    Just asking, you did remember to remove the holding push clip from the bolt prior to tiring to remove it, correct???
    Al in Kazoo
    2018 F3-T
    2018 F3-T , Pearl White
    Jul 2021
    FL
    Quote Originally Posted by IGETAROUND View Post
    Al in Kazoo
    Yes Sir, I did. The caliper's bolts were just as bad but I could get much better leverage and torque to get them out. Tomorrow I'm going to try removing that bolt with the caliper still on the trike, in hindsight that's what I should have done...live and learn.
    Durham,Maine
    Heat is your friend.
    2012 RTL , Pearl
    I'd be very very careful about spraying anything EXCEPT Brake cleaner near the Pads or Rotors .... Try heating the bolts with a Soldering Iron .... also after getting the tool onto the bolt give it a few sharp raps with a hammer ... this works really well on OIL plugs .... good luck ....Mike
    Mar 2021
    Maryland
    Yep I have a little bernzomatic torch like lamonster has in this video, it was only about $20 at lowes and came with a solder tip so I don't have to plug in to solder anymore unless I have something delicate.
    It has a nice small little flame and keeps the heat right where you need it on the bolt. Only takes about 15-20 seconds to loosen anything up.
    2020 F3 SE6
    2020 F3 , Black
    Jul 2021
    FL
    Thank you all for your help!
    I was away for a few days, so today I tried it again: A few sharp raps per Mike's suggestion, kind of hard because of limited space, then I tightened the bolt as far as I had loosened it before, a couple more raps and the little bugger finally came out.
    If that didn't work, I had the torch ready....
    The fronts were so much easier with much better access to those bolts.
