Results 1 to 3 of 3
    Mar 2021
    Maryland
    Default To the Board Admins: Search and post history are broken ....
    Can't search from the box on top right. Keep getting the error message below.
    connection to localhost:9312 failed (errno=111, msg=Connection refused)
    2020 F3 SE6
    2020 F3 , Black
    Sorry for the inconvenience, but it's been like this for some time.
    You should still be able to access the hardwired 'Today's Posts' or 'New Posts' searches, etc, but anything like 'View Form Posts' or anything that requires data input to generate the search criteria will likely get that same message.
    Admin was sent a message to this effect almost 14 hours ago now; so he is likely aware, but may have quite a few other issues to contend with at this time - we aren't the only site he looks after, and it seems there's a few having issues right now. However, he will get it back & working again for us as soon as he's able.
    x 2 Also experiencing the same.
