Results 1 to 25 of 34
Hybrid View
    Quote Originally Posted by OK-DZ9R View Post
    I expect to receive a lot of flame for this. I have a 2015 F3s with a Baja Ron stabilizer bar and Elka shocks. I just replaced the tires with Kenda KR20 Kanine's. They are designed for the Spyder. The previous Kenda's performed well and the Kanine's are even better in my experience. To each his own, but I'm not a fan of underinflated car tires.
    I won't Flame you on this .... because I'm not a fan of underinflated car tire ( or any other tires ) either. .... However if you understand the Science behind what PSI you should use, you should agree that a lightweight vehicle must have a PSI using the weight of that vehicle as the determining factor .....Mike
    Oct 2020
    Arizona
    No tire is under inflated until the PSI falls below the required amount for the weight it is carrying.
