Results 1 to 14 of 14
    Active Member LALoner's Avatar
    Oct 2022
    Louisiana
    Default Learning to Take the Turns!
    Beginning to learn my new F3-S . I think my new three word mantra is Push - Lean - Relax .
    Quote Originally Posted by LALoner View Post
    And relax in-between as well!
    Florida Swamp
    That is about it. Leaning is still part of taking a turn. It is not part of steering a trike, but it is important to lean, because it keeps your butt firmly rooted in the saddle and not getting your body into any weight transfer to the outside of the turn. It might keep the inside wheel more firmly planted too, but mainly it is to keep you firmly planted in the saddle.
    I have been riding trikes for over 30 years, both the traditional, two in back, one in front style, and for the last 4 years, the Can Am reverse trike style. It is just a matter of getting used to the different steering and the different forces the turn places on your body. For most people, about 500 miles on a trike after riding 2 wheels all their life is all it takes. I had more trouble adjusting from a 4 speed to a 5 speed back 30 or 40 years ago than adjusting to the trike handing after 40 years or more on two wheels.
    2019 F3-S , Black & Silver
    and on the new Spyder.
    Bossier LoUiSiAna
    Well learning on Louisiana roads ...umm is well, maybe not quite same & as comparable to others flat curves, patch work ramps followed by potholes
    (sometimes in the curve/turn) & of course the drunks /meth heads& roadkill, then Another STOP light. (Got two green -you did something wrong- won’t get to repeat)
    Durham,Maine
    I will ad, when taking a turn, get use to push with your push arm, that will give your pull arm a break! It's easier to push than pull the bars.
    2012 RTL , Pearl
    Oct 2022
    Louisiana
    I have been running around the lake . If you look on google earth you can see the turns on S Lakeshore and a few sweepers on N Lakeshore. Not the " backbone " but better than most ares around here . It makes a quick 34 mile ride from the house .
    Vermont
    When you make left hand turns, you push thru the curves.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member Smokes's Avatar
    Jan 2017
    Melbourne, Australia
    Also relax your grip on the handlebars. Don't hold on too tight.
    Andrew
    Melbourne Australia
    2016 F3L Spyder
    Now, wash your hands
    indpls in
    Don't lean, all that does is take away your push on the bar! Sit up straight, push with your arm and the same leg on the floor board.
    Oct 2020
    Arizona
    Quote Originally Posted by fatboy View Post
    That works OK for short people! For taller people, leaning in, down, and forward, plus looking to where you want to go, allows for fast cornering in the twisties.
    Last edited by Peter Aawen; 04-12-2024 at 07:54 AM. Reason: Fixed quote display ;-)
    I agree with Snoking1127. Leaning can be good...
    Aug 2019
    Stoughton, WI
    Especially on 2020/newer RT's ....
    2022 RT Sea To Sky
    Active Member Dasmoetorhead's Avatar
    Jun 2023
    Tennessee
    Yep, leaning.
    Retired U.S. Coast Guard 76-97
    2022 F3S , Monolith black
