Results 1 to 7 of 7
    May 2022
    California
    Default Anyone have experience with DVR Placement? Where did you put yours?
    Planning on mounting a camera system with a DVR. The DVR needs to be fairly level as it has a G-sensor. Does anyone have experience with something like this? If it's to be tucked away, where have people found a place to put it? I'm not seeing a lot of level space for it.
    NOTE: it will be hidden but needs to be accessible.
    Last edited by Peter Aawen; 04-18-2024 at 11:29 PM. Reason: Removed Prefix - this is not a HowTo: DIY thread... And expanded title to briefly state the reason for the thread! ;-)
    Dec 2020
    Down South
    That sounds fancy. I'd like to know how it works out b/c it sounds like an interesting set up. Are you doing a permanent mount of the camera? If not, are you opposed to just using a camera with an SD card?
    '20 RT Chalk Metallic
    May 2022
    California
    JohnRuckus, It is a camera with an SD card. Here is the link of the one I bought. It's not that fancy but someone I know has one and likes it. I'm looking to mount it somewhere out of sight but still accessible to get to the SD card. Wondering if anyone has done anything like this...
    https://www.amazon.com/KENWOOD-STZ-R...st_sto_dp&th=1
    BTW. My Bike is basically the same as yours...
    Mar 2015
    Indianapolis, IN
    Since you don't have a signature line stating such - you might mention what Spyder you are trying to put this on. That will get you better suggestions relative to your bike.
    Joshua
    2016 Spyder F3S
    2019 Spyder RT Limited
    2022 Ryker Rally
    2016 F3S , Triple Black
    Jul 2011
    Mitchell, Ontario, Canada
    I have a different camera system but is similar, installed on my 2018 F3L. I put the DVR under the pillion seat. Easy to get to. Take a look there on your mystery Spyder. That may work on yours.
    May 2022
    California
    Thank you all for your feedback. I will be more clear next time.
    Clinton, MS
    Quote Originally Posted by Krdcm View Post
    Well, what are you putting it on? There are several dashcam threads you can research on here. I wouldn't drive without one.
    2019 RTL Phoenix Orange
Tags for this Thread
