Results 1 to 11 of 11
    Jan 2024
    Texas
    Default Saw the GPX Route Files for rides/rallies - which software do you recomend? (iPhone)
    I saw GPX route files on the Hot Springs rally page for download. I see that the Pro version of Rever can import these.
    Any other software that you guys use/recommend? (iPhone)
    Last edited by Peter Aawen; 04-22-2024 at 07:53 PM. Reason: Expanded title to briefly ask the question... ;-)
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Clinton, MS
    You should be able to open these in Google maps
    2019 RTL Phoenix Orange
    Sep 2020
    Middletown, NJ
    Look at MRA. May be the current best for iphone.
    https://www.myrouteapp.com/en/information
    2020 RT base , Chalk White
    Jan 2024
    Texas
    (I'm not sure if this is the best forum or not for this -- Mods feel free to move it if there's a better one.)
    First off, I don't even have BRP connected to my phone... I gave up on it. I use a "dash" mounted phone connected my cardo in my helmet via Bluetooth.
    I also am going to the Hot Springs Rally next month, and they have .GPX files to import, but Rever requires the premium edition to do so.
    I typically just use Apple maps or Google maps for GPS guidance, and if I want to try backroads, I set "avoid highways", but that rarely accomplishes exactly what I want, and I manually select another route, etc. But I do have Rever downloaded, just haven't signed up and used it yet. Someone else suggested MyRouteApp.
    So, that's all a long intro to ask what phone app are you using to plan / track / provide nav guidance, etc. on your phones? Preferably one that allows for easy screenshots or sharing to the web/social media after it's done. Perhaps also allows for location tagged notes/photos for searching later? Also can import GPX files for runs, etc?
    Last edited by Peter Aawen; 04-23-2024 at 03:34 PM. Reason: Moved Post title after merging duplicated threads - they mess with Searching! ;-)
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Active Member MarkN's Avatar
    Mar 2022
    Mio, Michigan
    I have used Scenic, Sygic and inRoute. I have subscriptions to Scenic and Sygic. They all import and export .gpx files and Scenic can import Google map routes. Free to download and try.
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    2021 600 , Black/Yellow
    Mar 2022
    Mio, Michigan
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    Apr 2024
    On
    I use Scenic and love it
    Feb 2012
    Spring City,Utah
    +1 on the MRA. Great app and easy to use
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    I will 2nd the previous poster. MyRoute App is, in my opinion, the best all round routing app, regardless of the device.
    2022 Plasma Red, F3 Limited, Special Series
    I used to like the Rand McNally paper maps.
    We bought a new Garmin for the trip from AK to AR in 2019. It sent me down a wrong road in Iowa and took me 20 miles out of the way before I caught the error. I have used it very little since that time.
    Jan 2024
    Texas
    Yep. Garmin has gotten a lot better (my built-in nav for my car still uses Garmin), but I used separate Garmin dashboard devices for the cage since they first came out, until the smartphones made them obsolete, imo. I used to end up in farmer's fields, dead ends where the ferry doesn't run anymore, and all of that. Part of the adventure I guess. But that hasn't happened with the current shared data apps like Apple Maps, Google, Waze, etc.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
