Page 4 of 4 FirstFirst 1234
Results 76 to 86 of 86
  1. #76
    Mar 2018
    south africa
    Hi do you pls have the clutch kit parts number pls
    Regards
  2. #77
    Sep 2020
    Platte City, MO
    Just a heads-up, this thread dates from 2012, so some of the posters may not still be active.
  3. #78
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by ddtoit View Post
    Regards
    You are not giving us much to go on. May I suggest next time including all the details about your Spyder. Model, Year and any mods that may be important. With that I will take a guess at what you may be asking. So here is an exploded view of a clutch for a 2015 991 SE5 clutch assembly. Is this what you are looking for or are you looking for the slave cylinder parts.
  4. #79
    Feb 2012
    Spring City,Utah
    I see that this question was never answered. Does anybody know at what point the extended nozzle was incorporated on the assembly line? and yes I know it is a way old post, but it is relevant to a current post by somebody else with clutch problems and there are also a lot of us still here with old VTwins who may be approaching a mileage that will warrant a clutch repair.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  5. #80
    Nov 2015
    Chardon, OH
    Hey Bud. It was standard for the 998 starting in 2013. The SE5 and SM5 had different part numbers, but both had the extended nozzle. Look on the parts exploded diagrams for Engine Lubrication. It’s shown just above the engine oil filter, piece #23. Easy to get to. Never heard that the extended nozzle couldn't be used while keeping the original clutch, or if that would be beneficial at all. It was only the disc kit that was changed. But, I never changed mine. (If it ain't broke.....) It’s in the shop manual in the Lubrication Section. Post #17 back on page 1 shows location.
    Doug
    ”Freedom is not a loophole”
  6. #81
    Active Member VLADI's Avatar
    Nov 2019
    Russia Volgograd
    I will not start a new topic, I will write here. Two weeks ago, transmissions went missing while driving. You squeeze the clutch, turn on the gear and not what happens and the metallic clang is audible, there are no extraneous sounds on the neutral. I dragged him into the garage with difficulty. The assumption is that the clutch discs broke off (it happened on motorcycles). The new original kit must wait about two months. Maybe someone knows the number of the clutch analogues? Is the same engine on aprilia, ktm, is the beul suitable for them? billybovine also pointed out that SM and SE are the same, from SE there is on Aliexpress (I don't know if this resource is used on the other side of the ocean) but will it work?
    We are Russians, God be with us!
  7. #82
    Quote Originally Posted by VLADI View Post
    A member here ( Blackpheonix38 ) just posted about a clutch kit made by " TREAL " (?) for the V-twin engine and He said it was a big improvement .....Mike
  8. #83
    Nov 2019
    Russia Volgograd
    I did not find such information in this topic. If it's not difficult, specify the number. It is difficult to search from English.
  9. #84
    I'm not sure you'll easily find the number, so you might need to talk to them - Type the word 'Treal' into the Search field up toward the Top Right of this page; click on the 'Search Titles Only' box in the drop-down list below it, and once you've submitted the search, have a read of the resulting threads, altho it doesn't look like too many will have much to do with clutches!
    OR
    , you could go to the Treal Performance website here: https://trealperformance.com/ and then use their Contact Page to try and describe what you're after & get some help there... But they probably have the same issues with translation as you do, only worse!
  10. #85
    Durham,Maine
    Treal Proformance looks like it specializes in Ryker and CVT set ups. I think he's looking for a clutch kit for a standard style 998 set up! I may be wrong!!
    2012 RTL , Pearl
  11. #86
    Nov 2019
    Russia Volgograd
    Yes. I have a 2008 GS. Only links to ryker can be found on the site.
