Results 1 to 5 of 5
    Active Member MonPaul's Avatar
    Feb 2019
    Central WI
    Default Swapped Battery, radio presets kept - how is that memory powered?
    Just finished swapping out batteries on 2018 RTL (if you have fat hands like me, get a skinny friend to help) and was surprised to see my radio station presets were still there and I had nothing to change! The old battery was out of the bike for days waiting for my new one to come, so I assume there is some internal memory. If so, where does that power come from? I am curious how this works.
    Last edited by Peter Aawen; 05-01-2024 at 07:50 PM. Reason: Expanded title to briefly ask the question... ;-)
    Mar 2017
    Salisbury,NC
    it might be something like an EPROM flash semiconducter that stores those features at key off. Your total mileage and trip meters are saved forever, so maybe the radio presets too
    Florida Swamp
    Non-volitile memory chips....... various types with varying properties.
    https://en.wikipedia.org/wiki/Non-volatile_memory
    There can also be a small battery good for many years on a circuit board that can maintain a small volume of information for many years.
    Some of the chips can be reprogrammed when power is on; but will hold the same zeros and ones when the power goes off.
    Been a lot of advancements in computer chips in the last 3 or 4 decades and some of it is not well known. The miniturisation and addition of huge amounts of storage space is fairly well known, however, many of the Hard Disk systems which stored information magnetically on a disk, are now being replaced entirely by Solid State Drives, which store information on memory chips similar to a thumb drive. The advantages are much faster read and write, as well as zero moving parts. Solid state drives come in a vast array of capacities, with the larger ones able to replace the traditional disk storage hard drives on laptops and other devices.
    2019 F3-S , Black & Silver
    Bossier LoUiSiAna
    How about trip meters? usually what gets lost on mine 13
    Member f110tech's Avatar
    May 2024
    Massachusetts
    Quote Originally Posted by Gwolf View Post
    , Comp-Sci Major
    Depends on the engineer that designed the circuit for the instrument cluster. If they feel there is no need to save a simple trip meter setting than it could be easily overlooked in the design.
    Current Ride: 2015 RT Limited
    Previous Rides
    2015 Kawasaki Vulcan Nomad 1600
    2006 Kawasaki Mean Streak 1600
    1985 Kawasaki Eliminator ZL900 w/2003 ZRX1200 Stage 3
