Results 1 to 25 of 34
    Clinton, MS
    Default Using 4 FOBO TPMS senders to monitor the tires + ACS too!
    Saw this in JDT's WTB Ad - https://www.spyderlovers.com/forums/...s-for-2022-S2S
    Quote Originally Posted by JDTOLLAND View Post
    Folks
    I’m looking FOBO tire pressure monitors for my bike - a question: if I use 4 of them, is it possible for read outs for the suspension schraeder valve? I’m new to using these, but at 60 years old it’s a convenient way to monitor psi.
    It's a great way to monitor your tire pressure and air bag pressure. They already have a profile set up for that.
    Last edited by Peter Aawen; 05-08-2024 at 03:53 PM. Reason: Removed other's questions/discussion from OP's Ad
    2019 RTL Phoenix Orange
    Apr 2024
    On
    So do you buy 2 packs of 2 wheel Fobo packs ?
    indpls in
    no theres a 3 pck
    Apr 2024
    On
    Yes, I know there is a 3 pack, but if you want to monitor 3 tires and the air suspension, you need 4 in total, so do you just buy 2 packs of the 2’s?
    indpls in
    the 2024 is auto air no need to monitor
    Northern Kalifornia
    Order 4, and beware. They are or can be a PITA to set up. But once they're working they are GREAT. From then on you don't have to get down on the ground to check that dam rear tire. One problem I've found is sometimes they get out of sync and don't want to sync up. Low, but not dead batteries, can cause that. Just slip in a new battery and it will most likely sync right up like they're supposed to. Good luck, great product.
    Dec 2020
    Hartwell, Ga
    I purchased two, two packs. Works great.
    Very Active Member Quickdraw's Avatar
    May 2021
    Upstate NY State
    Just curious. I know this is the wrong place to ask but are they worth it? If so, could I buy the set for cars and use 3 for the tires and the other for the rear shock?
    2021 RT Base - Petrol Blue
    Clinton, MS
    The sets for cars work a different way and a different app and don't interchange. They feed their signal to a small separate battery powered block that then bluetooths to your phone.
    Northern Kalifornia
    No, just pony up and go with the motorcycle 4 pack. You don't need the hassle of swapping them from vehicle to vehicle.
    Active Member GS1's Avatar
    Sep 2014
    New Jersey
    I have a set of the 1st gen FOBO, would need an Iphone for any updates, they work great but with an android updates were not option. $35.00 plus shipping
    Improvise, Adapt, Overcome, Semper Fi
    2020 RT
    Limited heated seats
    removable back rest & rack
    XK Glow light
    Paint with light painted panels
    (Gone but not forgotten ) 2009 RS SE5
    2020 RT , Chalk White
    Aug 2018
    Santa Ana, Ca
    Do you need metal air valves?
    Quote Originally Posted by Dean8 View Post
    Some people believe so, but NO, normal valve stems will work fine; altho the shorter stems are better than longer stems - they don't let the FOBO sensors flap around in the breeze so much.
    Sep 2014
    New Jersey
    no you do not just screw them on
    2020 RT
    XK Glow light
    Apr 2024
    On
    For those of you that have the FOBO2 bike installed for your air shock, what do you set the recommended low and high values to with original tires?
    My fronts I put at 20 recommended and 18 low and 25 high, rear 28 recommended and 26 low and 35 high
    Just sitting by itself my air shock was at 35, when I sat in the passenger seat it went up to 38, so I set my recommended at 35 and the low at 30 and high at 40. With this one really just want to make sure it goes up and down some depending on load to ensure it is actually working.
    Also, with the FOBO2 valves installed has anyone experienced them leaking air?
    Peter
    2024 Sea to Sky
    Jul 2021
    IL
    Have not experienced any noticeable air leakage with the FOBO2 system. I change the batteries in the sensors at the beginning of the riding season, and set the rear tire at 30 pounds, with the low warning at 24 and the high warning at 40. For the front tires, I set the pressure at 20 with the low warning at 15 and the high warning at 26. Last year, over the course of the riding season, the tires lost a bit of air, but not enough to make me crawl under the bike again. When I put the bike away for the winter months, my rear tire read 26 psi, and the front tires read 17 psi. I just left it that way until Spring when I added air and changed the batteries for this season. Best $150 I have spent since getting the Spyder 3 years ago.
    2021 Spyder RT
    2023 Royal Enfield Hunter 350
    Retired U.S. Army
    Life Member, NRA
    2021 RT , Petrol (blue)
    Harrington, Australia
    I am similar to you with tyres, Hancop, although I have mine set 3 below. With the airbag, I have low at 25 and high right up there at 80, as I know it can reach that with my 300+lbs on the RT. Like you, I just use it as an easy check to occasionally see how the airbag is going. Like Vito, I have never experienced leaking at any greater rate than tyres without FOBO.
    HeliBars Handlebars
    Kenda Kanine rear.
    Quote Originally Posted by Hancop View Post
    Peter
    In my experience, these FOBO Sensors leak air about as often as a normal tire valve/cap, so you'll likely lose more air when removing/refitting to adjust your tire pressures than you will at any other time...
    Altho, I must admit that once they start to get old, and the little 'rubber' cap seals inside the threaded bit start to wear out due to years of use, occasionally one of those seals might be forced into the valve stem around the pin that operates the valve itself, and this will generally start that sender get odd readings rather than leaking air 'out' of the tire. This is probably because valve on that tire is effectively jammed shut, so the tiny amount of air caught between the top of the valve & the sensor itself does funky things! But that did take a looong time/quite a few years before it started happening, so I doubt you'll remember this if it ever starts happening to you?!
    As for the bold bit I highlighted above, I don't think 40 psi is going to be anywhere near high enough as your maximum level, but it'll be interesting to hear what you report back.
    My reasoning for this doubt - I've seen how high the momentary pressure can reach once you start riding & hitting bumps in the road surface; I think you might be quite surprised at how high that bag pressure can get; and I reckon that with a max of 40 psi, unless they've significantly extended the required 'dwell time' to respond to high pressure readings, your 'pressure too high' warning may be continually activating!! Admittedly, it's been quite a while since I bothered to run a sensor on the ACS; and it's been more than quite a while since I effectively disabled that annoyingly failure-prone & problematic system by fitting a shock/coil assembly that doesn't NEED the air bag to hold the blunt end of the Spyder off the tire, so I can't remember the max pressures it used to frequently reach... but I do remember it being a pain, cos the tiniest change to the 'load' on the rear suspension will cause a significant change in the air bag pressure!! So please, do tell us how that setting goes for you?!
    Good Luck!
    Active Member T.P.'s Avatar
    APPLE VALLEY, MN
    I installed a 4 set of the bike FOBO’s on a Friends Spyder yesterday. Reverse trike with air shock.
    Noticed that the new FOBO’s are smaller than the ones I got in 2017.
    Fast and easy, no BS. ��
    T.P.
    May 2021
    Upstate NY State
    How did you end up successfully running the firmware update? I tried multiple times yesterday but kept getting disconnected from the sensor. Once it disconnects, it wants me to remove the sensor for 8 seconds and try again. Never seems to fix the issue though.
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Quickdraw View Post
    All that I did was install them and the set it up for the reverse trike with air bag.
    The only glitch that I had was one sensor did not connect until I rolled the spyder out of the garage and it connected then. I put this off to me having a metal roof on my House/garage.
    Try moving outside and then install them. Sometimes things get in the way of wifi & internet connections.
    also when installing them make sure to do it one at a time with the others moved away from the one that you are installing.
    May 2021
    Upstate NY State
    I was outside when I installed them. They are working now, now that I figured out from the video they had to be done 1 at a time and before removing all of the paper between the battery and the device. At least they're working. At some point I'll try and update the firmware. They did tell me a story about my last visit to the dealer. I asked them to add air to the fronts and back. Apparently they never did that. The right front was down to 13 pounds. The AS shock was way down. I told the wife I'm going to save up and replace that shock next year with a regular shock. I'm tired of it losing air all the time.
    APPLE VALLEY, MN
    HEY QUICKDRAW. Just Wait 'til you find out that rear AIR-SHOCK isn’t really an air shock.
    T.P.
    May 2021
    Upstate NY State
    Quote Originally Posted by T.P. View Post
    T.P.
    It is because I've filled it up numerous times. It's an air-filled shock, just not one that is auto-fill. That's on the RTL.
    On another note, one of my front tires was flat Thursday so I filled it up. The next day, it was flat again. I filled it up this morning and this afternoon it was flatter than flat. So, I figured when installed the locking nut, I went too far when putting it on and pierced my valve stem. When I got home, I filled it up and did a soap test. There was no leak. So, the only logical solution was to remove the locking nut. That did the trick. Apparently, the sensor wasn't able to screw in all the way because I was not able to get the locking nut screwed in far enough, and it was leaking air. Removing the nut fix the issue. So now either I leave the locking nuts off or remove the beveled part on the back of the nut so I can get it on the valve further. I'm not really sure I need that lock nut where I live.
    Kind of a strange situation that the lock nut was causing the issue. Odd though that the rear tire isn't having this problem. The rear shock valve has plenty of thread on it so that's not an issue either.
    APPLE VALLEY, MN
    T.P.
    It is because I've filled it up numerous times. It's an air-filled shock....
    https://can-am-shop.brp.com/on-road/...2107/26Y2107/y
    Last edited by Peter Aawen; 06-01-2024 at 08:24 PM. Reason: Fixed quote display; added Bold/Underline ;-)
