Results 1 to 11 of 11
    Feb 2024
    Ohio
    Default Anyone have any good Headlight upgrade suggestions?
    After riding in the dark a couple times, I realize the headlights on this 2008 GS are terrible. I searched headlight upgrades and couldn't find anything that provided a good upgrade to the current lights. I believe the design of the headlights is probably the culprit. Anyone have any good suggestions on how to get better headlights for riding after dark?
    Last edited by Peter Aawen; 05-06-2024 at 04:59 PM. Reason: Expanded title to briefly ask the question... ;-)
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Quote Originally Posted by SamHuskyguy View Post
    See what number bulbs are in it and go to Amazon lots of LEDs available.
    2016 RT Limited Orbital Blue. Ultimate seat
    Bajaron swaybar,PV3 with BLR custom Tune
    Farrod front car tires p165/65/15
    Led headlights and fog lights
    Showchrome windshield.
    Two Brothers Muffler and cat delete pipe.
    Quote Originally Posted by helton61 View Post
    .... I use the FAHREN brand and they work very very well ... 16,000 lumens .... or you can get higher - get the ones without the fan .....Mike
    Aug 2022
    North Carolina
    Actually just did this upgrade on my RSS. I ended up using the 22000 lumen AUXBEAM bulbs and it definitely made a big different. Check out my video I made.
    https://youtu.be/xEXJzwdU5dk?si=My8XN2VZ0QXymR6v
    Chris
    2012 CanAm Spyder RSS
    2012 RSS , Orange and black
    Active Member DickB's Avatar
    Jun 2021
    Lake Placid, FL
    Consider adding auxiliary lights such as Denali.
    2019 Ryker Rally
    2014 Spyder RSS
    Feb 2024
    Ohio
    Blueknight911, do you know what model FAHREN bulbs you used?
    I doubt mine would fit your 2010 ..... read the above post # 4. ..... His was an H-7 LED but it was for the RSS and You have an RT which has different style headlights ..... but check your owner's manual and see what it says ....Mike
    Feb 2024
    Ohio
    In the video they look the same. But I'll check the owners manual. Auxbeam does make various replacement types, so hopefully they have a set that will fit mine. I might take DickB's advice and add auxiliary lights as well.
    Oct 2022
    cornwall ,ontario,canada
    Hi i am looking at these will this work for my 2010 rt-s
    FAHREN 9005/HB3 LED Headlight Bulbs, 22000LM 600% Bright LED Headlights Conversion Kit 6000K Cool White IP68 Waterproof, Pack of 2
    Quote Originally Posted by langevn View Post
    That's what I have in my 14 RT ( only 16,000 lumens tho ) ..... maybe someone can confirm that your 2010 RT uses the same bulb/ led .....Mike
    Feb 2024
    Ohio
    langevn, That's what I was thinking about using. I'm hoping they work. Also, my projector beam lenses look cloudy. Is there a way to clean them inside?
