Results 1 to 7 of 7
    Mar 2015
    Brockport, NY
    Default Anyone got Part Numbers for Replacement Gold Plugs on '22 or newer RT?
    My transmission side drain plug stripped during my oil change, so I ordered the replacement Gold Plugs from their web site. When I searched for Spyder plugs I found only 2 and ordered as noted below.
    MP01 M12x1.5 Gold Plug Magnetic Drain Plug; and
    MP02 M14x1.5 Gold Plug Magnetic Drain Plug.
    I installed the transmission side and although it looked shorter, the thread pitch was right, so I installed it. I went to install the oil side and it was too short to engage with threads and did not have any place for the 'O' rings! Has anyone added the Gold Plugs to a 2022 or newer RT? If so, might you have the part numbers?
    Transmission plugs:
    Oil plugs:
    Last edited by Peter Aawen; 05-10-2024 at 07:11 PM. Reason: Expanded title to briefly ask the question... ;-)
    2014 RT-S Pearl White
    Clinton, MS
    If you order from Lamonster or BajaRon you will get the right plugs. They are the same for all the 1330's.
    2019 RTL Phoenix Orange
    Mar 2015
    Brockport, NY
    I ordered directly from Gold Plug
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Brentc View Post
    "Lick your wounds" & order a set from Lamonster Garage!
    You will get the RIGHT ones!
    MHO, Bill
    If in Doubt, Don't Do It!
    Nov 2015
    Chardon, OH
    Hey Brent. Well, just in case you wanted to stick with the gold plug, the engine plug is the MP18. Their year, make, model search is a little screwy. If you go back to 2020 or so, Can Am shows up and the correct plugs show up. MP01 is the correct clutch cover plug. Exactly the same plugs as your 2014.
    Doug
    ”Freedom is not a loophole”
    Oct 2022
    Jacksonville, IL
    The ones I got from Lamonster are both hexhead. The one
    2016 Spyder RTL SE6
    Mar 2015
    Brockport, NY
    Thank you everyone, I have found the info I need.
    Much appreciated.
