Results 1 to 4 of 4
    Mar 2024
    CA
    Default Where is the gas tank vent tube on '20 RT?
    Can anyone point me to the location of the gas tank vent on a 2020 RT Limited? A general location is fine. I just want to take off the least amount of plastic getting to it. I will be using it to connect an aux tank. If you have a picture, even better.
    Last edited by Peter Aawen; 05-12-2024 at 08:05 PM. Reason: Removed Prefix - this is not a HowTo: DIY thread... & expanded title to briefly state the reason for the thread! ;-)
    Oct 2020
    Vinton, IA
    You will have to remove the passenger seat, then driver, then the panel that covers the tank & surrounds the dipstick. The lines to & from the gas tank should be visible on the right side, top. I don't have a pic of the right side showing the sending unit & lines, but here is one that shows the lines to/from the fuel vapor canister located under the side panel just inside the left sidecase release handle. Sorry for all the dust!
    Hope this helps.
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
    Durham,Maine
    Quote Originally Posted by spyderdave View Post
    Hope this helps.
    My, My, you look like you're having fun! Got her all undressed!!! Mine looked like that a couple weeks ago. Plugs, wires and an air box mod!
    2012 RTL , Pearl
    Mar 2024
    CA
    Many thanks spyderdave, just the info I needed.
