Results 1 to 25 of 39
    Ultimate Spyderlover
    May 2012
    McComb, MS
    Default Heat in the Seat.....Ouch!
    I'm sure there are many spyderlovers who love riding the spyder to work like I do. But man does it hurt to sit on the spyder after it's been sitting for a few hours in non-shaded 104 degree heat! Lol
    I'm brainstorming on something to put over it. What do you guys use?
    Mar 2009
    Beavercreek, Ohio
    Get some white material and make "sheet" that goe from the grab bar to the windshield. sew holes and use light bungee cords.
    I would love to see somebody make a light covered "washable" cover that would go over the Trunk and the windshield.
    Oldmanzues
    Teddys favorite human
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Cool
    Quote Originally Posted by Kratos View Post
    I'm sure there are many spyderlovers who love riding the spyder to work like I do. But man does it hurt to sit on the spyder after it's been sitting for a few hours in non-shaded 104 degree heat! I'm brainstorming on something to put over it. What do you guys use?
    I ryde Teds Red Sled every day in ALL weather conditions, but I've never really had an issue with the seat being too hot (Guess I have a fatter A*s than I thought-)
    We do have the travel cover and I suppose, if the seat temp bothered me too much, that I'd just put the travel cover on, as it only takes a minute or two to put on and take off, and it covers the entire top of the byke, so the seat should not be scalding like you say yours is. I have also seen a local RS ryder that uses a beach towel when he parks in the sun, but you'd have to have a way of weighing or strapping it down.
    Ive also seen many other ryders with many different types of seat pads, like those Dyna-Beads and the Air-Cushions, maybe something like one of these might help as well Good luck & let us know what helps you out
    zrc
    Guest
    http://www.motorcyclegear.com/parts/...alf_cover.html
    28.99
    Easy stuff there. Cheap, works, and cool.
    Mar 2011
    Fair Oaks, CA
    I have an Alaska Leather buttpad (aka sheepskin) and it works great! I never have to worry about hot buns and it removes quickly with the clips on each side.
    http://www.alaskaleatheronline.com/s...over%2C/Detail
    Otherwise, if you're looking for a real inexpensive option, you can raise your seat and wrap a towel around it, then lower it and lock the towel ends under the seat.
    Anthing that you can throw over the seat and secure so that it won't blow away will do the trick... Throw it in the frunk when it's time to hit the road and you're good to go!
    Free Thinking Member
    Apr 2009
    Southwest MI
    Check out these SeatSkinz from CoverAlls.
    http://www.coveralls.biz/store/motorcycles/
    Mar 2011
    Washington, D.C.
    Beadrider keeps my butt off the seat-- even though it's black there's enough of a gap that it's never too hot sitting down on a hot day.
    Unfortunately, I've discovered that this summer the heat coming *through* my seat while riding is getting unbearable. I don't know why that is (I swapped out my exhaust gaskets for the Honda gaskets in the spring, there shouldn't be any additional heat coming up), but I've found I can't use either the Airhawk *or* the sheepskin without getting waaay too much saddle heat coming up while riding. The Beadrider is frankly all I can stand to use these days, and even then I find myself needing to splay my legs out on my highway pegs from time to time to rush enough airflow under my butt to cool it off.
    Last year I bought some reflective tape to put underneath my seat/side panels, I'm going to try that once I have a cool-enough day to work on the bike. I just find it funny how I've always been an outlier-- I never had *right* side heat problems (and definitely don't now, not with Spyderpops gear on the bike), but my left side and saddle have always been crazy heat sources on the bike, even after the gaskets were replaced.
    Feb 2008
    Oro Valley, AZ
    2 solutions: Beadrider, and Cool Ass seat cover.
    http://genuinecoolass.com/
    http://www.beadrider.com/
    Highly recommended from a place where 104 is considered "not too bad"
    Jun 2010
    Las Vegas
    I took an old beach towel and attached elastic to the corners. It goes around the mirrors and over the rear trunk.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Invalid Emails
    Jun 2010
    Jackson, Michigan
    Can't beat the sheepskin as far as I'm concerned....
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    Used it on the RS and use it on the RT. Easy on & off. Durable. Very light weight. Really small when rolled up. Totally keeps the seat cool and is rain proof.
    2022 Plasma Red, F3 Limited, Special Series
    Thinks out loud
    Apr 2012
    The travel cover works well, if you don't have to worry about some one needing it more than you do.
    May 2012
    McComb, MS
    Lots of great options guys. Thanks....I was thinking of the towel idea also, but I wanted to make sure I wasn't just being a Mississippian....LOL
    Active Member viperryder's Avatar
    Oct 2011
    Ohio
    Default Heat in the seat
    When we are done riding I just take my helmet off and lay it on my seat and my wife does the same thing. So far this has worked for us. It's cheap and as long as no one wants your helmet as badly as you, you should be fine.
    2014 RTS SE6 , Cognac
    Active Member Recluze's Avatar
    Jan 2009
    St george, UT
    Beadrider for some 50,000 miles now. I finaly had to paint it this year because it got faded. And no one is likely to steal it. It is by far the most ugly and useful thing I have added.
    http://bobspyder.wordpress.com/
    #610 2007-2009
    #104 2012....
    Invalid Emails
    Sep 2009
    west Texas
    Quote Originally Posted by SpydherLuv View Post
    We also have the Alaska Leather sheepskins and they work really well. Keeps the seat cooler in the summer and warmer in the winter and always more comfortable to sit on.
    Cotton
    May 2011
    USA
    Use a lightweight cover such as this:
    Not only does it keep the seat cool it also protects against UV rays which will fade and deteriorate your expensive to replace seat and dash. It also protects against rain and keeps the kids off your Spyder when it's parked and you're away. It hides your GPS and other mods. It easily compresses into a tiny area and takes very little room in the trunk. I can put it on or take it off in less than 30 seconds. I don't know why everyone doesn't use one.
    May 2011
    Valley Springs, CA
    Default Hot Seat
    I use one made by Cycle Shade here in CA. www.cycleshade.com You won't see a spyder pic on the website but the shade that fits the GoldWing will fit the RT. It has two parts, One covers the Windscreen and the other covers the seat. Love mine.
    Oct 2009
    ponte vedra beach fl
    me 2 works great
    Very Active Member spyder3's Avatar
    Apr 2011
    Burlington, NJ
    kontour seat does not get hot(its mesh) and flows air nicely.
    Features & benefits: http://kontourseat.com/id2.html
    Rewaco RF-1 GT
    Inline 4 cylinder Ford Zetec with multi-port fuel inject, 140 HP
    0-60mph: 5.8 seconds
    5 speed sync manual with reverse, mechanical dry clutch.
    Front suspension: Trapezoidal fork with center spring
    Rear suspension: Independent with Bilstein gas shock absorbers
    Brake System: Grimeca calipers, linked ventilated discs, with booster
    10.57 gallons
    I couldn't even begin to keep track of where I was in a word like that if I had to type it!
    Kind of like "banana"; only much more interesting!
    May 2009
    Connecticut
    Quote Originally Posted by Littlebadwolf View Post
    I bought the Alaska Sheep skin and its Great BUT on a Hot , Humid day like today I just put on the Beadriders for circulation under your Rear and Baby Powder you know where before?
    Sea Doo GTI-SE 90 Jet Ski!!
    Northern Kansas City, MO
    Default Cheap not so easy
    I cheated, as I run a fabric store. Grabbed so knit fabric, either matching or for my prototype, white. A lil elastic around the edges. That was the not so easy part. Painted on a couple of spiders. Now I throw my leg over, never worrying about heat. Never having to move a bike cover, and just throw it in the wash.
    V
    MOgang Member
    Jun 2010
    Jeff City, MO
    Quote Originally Posted by tofriendscreek View Post
    Which one did you have for your RS... the DS, DSXL or the CS?
