Results 1 to 20 of 20
    Canada
    Default FOUND A GOOD BUG REMOVER FOR SPYDER
    Regina-20130607-00138.jpg This stuff works great.
    Invalid Emails
    Ormond Beach FL
    Liquid or spray?
    What does it do to vinyl pinstripe tape do you know yet?
    Nov 2012
    Pineville, LA
    Default Bug Remover
    I use Walmart Baby Wipes.. They work great..
    Jun 2010
    Las Vegas
    Where did you buy it? I had some bug remover made for RVs and it worked good but I ran out and didn't replace it.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2012
    Waynesboro, PA
    Just ordered from Amazon.com. Figured I would give it a try
    It has been mentioned in other threads, but, Hydrogen Peroxide works great for disolving the bugs. I am currently using a 50/50 solution with water.
    MOgang Member & Pyro-Man
    Jan 2012
    Troy, MO.
    I'm rather partial to Lucas Oil's Slick Mist. I keep a bottle in the frunk. It's a great, quick way to give your bike a nice shine in less than five minutes. I also use it on the windscreen. It makes bug removal easier when the time comes. Also, spraying on bug ridden parts and letting it set for a minute will remove them pronto. ImageUploadedByTapatalk1370658938.016868.jpg
    SpyderLovers Sponsor scooterexpress's Avatar
    Mar 2012
    ft-worth texas
    I tried the 50/50 it was useless in my book it didnt get any bug guts off my window or my spyder unless you putin some elbow grease in it.i bought some stuff called bugs be gone from the auto store now that worked great.sorry just my opinion.and I just washed the bikethis last weekend.
    Tall flag mount, spyderpops skid plate & stainless steel screen mesh, airhawk adjustable cushion, raised white lettered tires.
    Active Member RanHag's Avatar
    Nov 2011
    Nederland,TX
    I have found that Bike Spirits Cleaner and Polish works great on all surfaces.
    ESCI LED Brake Light, Ram mounts including ATV mount, mug holder and phone/GPS holder. Lamonster's NBV highway brackets. My version of Running Boards, Skid Plate, Bajaron's anti-sway bar, Dual flag bracket and flags. Bad Boy air horn. BRP air deflectors, Non-BRP hitch and USA Minitrailer Nomad, SENA Bluetooth Dongle.
    Canada
    Default Canada Motorcycle
    Here is the link: http://www.canadasmotorcycle.ca/motu...t-remover.html
    Dec 2010
    Telford, UK
    Quote Originally Posted by Can-Am Poogs View Post
    I found it on UK E-Bay and I'll have it by Tuesday. Thanks for taking the time to recommend this stuff, now that our weather has warmed up the Kamikaze bugs are out in force.
    Invalid Emails
    Apr 2011
    St. Clair, Missouri
    I use Gater Glo on my Spyder. Just spray and wipe. Works really good on windshield also.
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    Pro Honda Cleaner is the best I've found and I use it on everything except rubber and leather.
    JT
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Bugs Bugs Bugs
    I've tried many and recently was at the Auto Show in Florida where IBIZ was demonstrating all their products, including World Class Waterless Wash and Wax. So as any 'show goer' does, I watched and listened. Well, to my surprise, it actually works in the real world of Bugs Bugs Bugs. Also leaves a nice slick on everything, including the windscreen so the water really leaves in the rain. Not trying sell anything but I do recommend it. Easy on and easy off. If the bugs don't wipe off the first time, wait a few seconds and viola...gone.
    www.waxdirect.com
    will link you to complete line up of products that are pretty good.
    Apr 2013
    Philadelphia, PA
    There's no need to dilute the Hydrogen Peroxide. HP is H2O2, basically its water with an extra molecule of Oxygen. Its store in a brown container because after an extend period in daylight it becomes H20 (water).
    Motorbike Professor
    Mar 2008
    Allegan, MI
    Quote Originally Posted by aviscomi View Post
    The peroxide you buy at the drugstore is already diluted...usually only 3% hydrogen peroxide by volume. It makes no sense to dilute it further. If you can find the 6% stuff, even that should not require further dilution. The 30% lab grade peroxide might. Food grade 68% peroxide would for sure.
    Active Member Indyron's Avatar
    Apr 2013
    Sunbury, OH
    Default Invisible Glass
    I use Invisible Glass on the wind screen it takes off bugs and leaves a beautiful clear shine.
    2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
    Active Member RodO's Avatar
    Jul 2009
    Montréal, Canada
    Where did you get it?
    Ryde safe,
    Rod.
    '08 GS SM5 Full Moon -- after 15,000km sold May'11
    '10 RT A+C SE5 Full Moon -- after 30,700km traded in 2014
    '17 RTL Pearl White -- new-to-me in 2023
    "I guess its better to bend a valve in Missoula than to lose your mind in Bozeman", my wife said, patting my hand as if to console me. I winced and wondered if Phaedrus ever took the bus." -Peter Egan, Leanings
    CanAm Highway goes from Texas along U.S. Route 85 and Interstate 25 into Saskatchewan, Canada.<http://en.wikipedia.org/wiki/CanAm_Highway>
    Aug 2010
    Hopewell, VA
    I get the "Motul" from the bike shop, seems alot of the crotch rocket riders around here use it a lot.
    I learn something new here every day. Thanks.
