Results 1 to 7 of 7
Thread: Air filter
    Active Member va2djd's Avatar
    Apr 2010
    st jean sur richelieu
    Default Air filter
    Does any body have info about air filter or air box? New K&N filter? Or Bajaron Type? For 1330 ace
    Spyder RT LTD 2018 SE6 ASPHALT GREY METALLIC - DARK EDITION( Wife)
    Spyder F3T 2016 LTD Black Special Édition
    French Spyder Forum
    SpyderTeam Rive-Sud MTL
    Facebook
    https://www.facebook.com/groups/spyderteam/
    Twitter
    https://twitter.com/SpyderTeam_ca
    Jun 2011
    Near Lexington, NC
    This might open a can of worms for K&N owners so I've put my flame retardant suit on, but some years ago I read a comprehensive test (no, I don't recall where I read this) comparing K&N with various other types, pleated paper like is usually used in OEM's, and oiled foam. I had been using K&N's in my vehicles and bikes untill then. The test showed that pleated paper was the best, oiled foam second, and K&N last. K&N gets their claim of more power from the fact that it lets in more air thru its porous material.
    More air, more dirt. I don't use them anymore.
    OTOH, I doubt any of us will keep our bikes long enough for it to make a difference, so if it makes you feel good to use K&N, then do so, as thats really all that matters.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Jun 2011
    Near Lexington, NC
    I have read the article. The test was done with a Mazda Miata and was fairly well controlled. I believe it lives on Bob Is The Oil Guy website.
    On the flip side, I run a K&N in my 2 stroke KTM250exc dirt bike, but have removed the K&N from my 2010 Tacoma. Found like others, the Tacoma can be prone to picking up small amounts of filter oil onto the mass air sensor.
    All that said, I was having a look at the 1330 and will likely buy a K&N for the Spyder.
    PK
    If you find one that fits the 1330 I expect others will be interested as well.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Houston
    Agree completely. Ford sold quite a number of replacement turbochargers on diesel pickups thanks to the poor filtration of K&N Filters. Modern synthetic media pleated disposable air filters are much more efficient than the older paper ones, there is no longer a significant improvement in air flow going to the oiled gauze filter than there once was. K&N is in the same category as Slick 50, fuel line magnets and those split end v-power spark plugs. The only improvement in performance is the lighter weight in the owners wallet. Reduction in lifespan of the engine is easily measured in increased silicon in the oil analysis. Just say no.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2012
    Richmond, UT
    I guess someone should have told my 2001 Goldwing. I put 250,000 miles on it. Had a K & N filter from day one. Engine never burned oil and had never been apart when I sold it. Cheers, Larry
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by ldlexpress View Post
    You could probably have run kerosene instead of gas and no air filter at all and still got that much miles on it. Those critters just won't quit.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Apr 2012
    Richmond, UT
    Probably true. However I put 80000 on a 76 Honda 550, 90000 on a 79 Honda 750, 100,000 on a 86 Yamaha Venture Royal all running K & N filters. Not to mention my 66 Chevelle Malibu convertible that I raced for 3 years. Anyway they have worked well for me. Cheers, Larry
