Page 1 of 3 123 LastLast
Results 1 to 25 of 54
    May 2012
    pell city alabama
    Default CAR TIRES OR MOTORCYCLE TIRES
    The other I was setting constipated ..............AH contemplating things an it hit me every motorcycle safety class I've been to (2) wheels they told us to ride either right or left of center. this was to not get oil on our tires. So on our spyders we can't ride that way so does it matter what tire you use! Just my thoughts one morning
    May 2013
    Redlands, Ca
    It is obviously your choice.
    motorcycle tires are softer rubber. So they stick to the road better and give you a bigger contact patch. The Spyder is a very light vehicle at less than 1,000 pounds. Stickier and larger contact patch are good things--especially with wet pavement or emergency situations. However since motorcycle tires are softer and stickier they wear out faster.
    As as for me, I err on the side of reducing my risks. So, I use motorcycle tires on motorcycles--which the Spyder really is. I do not use car tires on my motorcycles, and I do not use motorcycle tires on my cars.
    May 2012
    pell city alabama
    Quote Originally Posted by Dan_Ashley View Post
    Well put But the car tire is as wide as the motorcycle tire an in my case wet roads = less grip motorcycle tires DO GIVE A BIT BETTER grip the main thing is what you like period oily tires of any kind = LESS GRIP THAT WAS WHAT I WAS trying to say.
    May 2013
    Redlands, Ca
    Quote Originally Posted by pellcitypete View Post
    Could you kindly put in some periods and commas? I do not understand what you are attempting to say. I believe that some punctuation would assist me in understanding you.
    Default Here's the thing..!!
    with a roadster you have to learn to to strattle to the right or left. This helps avoid the oil slick which only lasts till the rain washes it away. But mainly you don't hit object dead on with the back tire...so my wife says...!!
    Pete,
    We obviously can't ride the Spyder, the same way that we herded our "tipovers" down the road...
    Avoiding the "Grease Patch", isn't as important; but I still try to keep on just to the inside of a front tire. That usually keeps the rear tire out of it!
    That slo gives me a reason to move around in the lane, and make myself more visitble to the other traffic.
    Car tires, versus bike tires: if your dealer will mount them; it's completely your call!
    I used car tires out back, but stayed with Kendas up front... they did a decent job, and I had over 17,000 miles on them.
    By the way...
    Maybe this'll help with the OTHER problem...
    http://www.usatoday.com/story/news/n...psule/8513473/
    Nov 2012
    North Las Vegas, NV
    I just put a car tire on the rear of our RT. 205-60-15 Michelin Primacy. My wife and I can report that it feels fine and rides a little softer, plus the speedo is within 1 mph of the GPS now. No nanny issues either. Just hope this tire lasts longer than 8,700 miles. You could also check out the tires Rolo is selling.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Jun 2012
    Laguna Niguel, CA
    Default Car tires
    I've had car tires on the front for a couple of years and found they improve handling and stability. I would not go back.
    Aug 2013
    Quebec City, Quebec
    Quote Originally Posted by Ride Master View Post
    Same for me. I will never go back to kenda tires.
    Active Member DLewis's Avatar
    Greenwood, SC
    No more Kenda's for me either, Kuhmo on the rear.
    Houston
    I would really like to find a stiffer sidewall sticky tire for the front on 13s and newer using the 15" wheels. I am really not a fan of the soft sidewall kendas for cornering stability.
    Those Yokohamas look interesting if they had a 15 that would work.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Feb 2014
    Florida
    I rode a Honda VTX 1800 for over 30,000 miles with a car tire on the back.I had a blow out with a bike tire while pulling my Aspen camper and with no bike dealerships within a 100 miles.I went to Walmart and bought a tire.They would not mount it for me so I mounted it myself in the parking lot. I thought I would get home and change it out ,but the more I rode it the better I liked it. I rode the mountains and drug the floorboards in the rain .It stopped quicker and did some really cool burnouts. When my tires wear out on my 14 RT .I will probably go with car tires on it. My VTX used to get 6 to 7,000 miles on a rear tire no matter what brand I tried. That $69.00 car radial with balance beads still looked good after 30,000 miles.
    We've heard some reports that the Federals are pretty "sticky".
    http://www.federaltire.com/en/produc...ts_detail_sn=7
    Houston
    Anyone running these and can report back? They look interesting.
    Registered Users Ronbo's Avatar
    Mar 2013
    Arkansas
    Default Car Tires
    Anyone heard anything the new new arachnid tires.
    Ron
    May 2012
    pell city alabama
    SORRY I'M NOT A English PROFESSER
    One of our members is running them... He loved them!
    I'mjust not coming up with a name...
    Look in the tire threads over the past Month; it's been pretty recent!
    Maybe it was Guzzi???
    May 2012
    pell city alabama
    I have the original front tires on my spyder.... They have 15.000 miles on them, and still look new! Probably will go back original. Is this better?
    Hi Pete!
    If you've been having good luck with the originals; why not stick with them?
    I liked them on my bike...
    Sometimes; folks have trouble with a set of tires that have the inner belts separating. That causes all sorts of ride and handling issues. That's when they start looking to the aftermarket!
    Default THESE YOKO'S
    Quote Originally Posted by Mr Orange View Post
    ..OMG , I've been talking about these tires for months and you have kindly posted pics which I am unable to do........PS The 185/55 14 for the front actually has the largest footprint of " ANY " tire available for the 08 to 13 Spyders and they are V rated..........Thanks again
    May 2012
    pell city alabama
    Hi Pete!
    I am have a great time with my originals on the front the car tire on back is working good I am waiting to see how many miles I get with the car tire (13,000) with original)
    Apr 2013
    Long Island, New York
    So this tire will fit a 12rss front rim definaltey ?
    Default FITMENT
    Quote Originally Posted by librathe13th View Post
    .......... Fit the RIM ....Yes ......Squeeze it inside the fender ,,,maybe ?????........OK , I have the the same size 185/55 toyo proxces T1r tire on my 2014 RT.....and yes that's a 15 inch RIM..............But that really doesn't matter here , it's the 185/55 part that does......I have the BASIC model which has the OLD style fenders and other than putting two thick washers under the front fender brackets ( where it attaches to the hub ) these are the largest tires that will fit.......I don't know what style fenders you have ??????......Mikeguyver.........................PS , I don't think the Toyo's come in a 14 inch , and that's too BAD because they stick like glue and only cost $ 57 + shipping from the Tire Rack
    Mar 2012
    Florida Space Coast
    These tires will fit RTs? Do they hold up well?
    Apr 2011
    Hamilton,New Zealand
    Ok I am looking to replace my front whells but thay are 165/65/R14 your new one are 55 dose this make the VSS put you into limp mode or not sine thay are not the same size if it dose not then there are some better tires to look at here.
