ST tyre pressures
Sorry if this has been asked before.
I have checked in the 2013 ST owners manual and it states 1.03 bar (15psi) for the front tyres and 1.93 bar (28psi) for the rear tyres.
What tyre pressures are other ST owners running ?
If you are running higher than the recommended please explain why and what difference you have found.
Also do you increase them when riding 2 up ? and what do you increase them too ?
I usually stay at about what they recommend. My wife is a light weight so I require no adjustment for her.
I run 18 front and 28 rear.
I took the recommendation from BajaRon because he has been riding longer than me.
I don't change for 2 up because that would be a pain. Lol
I ride with 17 psi in front and 28 psi in rear.......Works for me
Same here.
