Results 1 to 23 of 23
    Brisbane, Australia
    Default 12v outlet in/on a RS-S
    Has anyone put a 12v outlet on a RS-S and if so how and where?
    May 2012
    sussex, nj and tug hill, ny (west turin)
    in the frunk on ours. can't help you on the other, as I took the easy way out and had the dealer do it!
    Mar 2012
    NJ
    The wires for the frunk outlet are tied up around the left front shock mount. Buy the $30 outlet from brp. The instructions are spot on and even include the template to drill the hole on the frunk.
    Apr 2013
    United States
    First I added a fuse block which can hold up to six devices switched or on unswitched. One of those is my outlet
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Quote Originally Posted by DrewNJ View Post
    i can't believe you just said ''FRUNK '' ............................
    it was fun while it lasted.
    Mar 2012
    NJ
    Quote Originally Posted by coz View Post
    Good point, it was actually more difficult than you think... I had to edit to get that. My tablet changed frunk to drunk...[emoji6]
    May 2011
    cincinnati, ohio
    i like drunk better............... cheers!
    Jun 2013
    Milford, Ohio
    I have a Battery Tender plug connected to my battery (the battery on a 2013 is in the trunk/frunk/drunk whatever you want to call it) and I bought a 12v outlet that plugs into it.
    Mar 2012
    NJ
    Jan 2013
    lancater ohio
    Default left front corner
    Used a extra open on the fuse block cut a hole in the ledt side easy!image.jpg
    Linden, CA
    Default Cycle Gear
    photo 1.jpgphoto 2.jpgHere is the best way to add a power outlet to your Spyder
    you can see it is on sale right now. mine works just fine i installed it in the dash, the wiring that comes
    with it is plenty long enough to go from the battery to the dash with extra... it is fused as well this way you
    bypass the Spyders electrical system.
    Dave
    Quote Originally Posted by ttc View Post
    Linden, CA
    I'm almost afraid to ask what that cost....
    Quote Originally Posted by spydaman60 View Post
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    On the dash, wires run from battery points with inline fuse.
    Sep 2014
    Los Angeles
    Dealer installed in the frunk.
    Sep 2014
    Los Angeles
    Like your location Piston, dealer stuck mine in the Frunk, not the most convenient.
    Mar 2012
    NJ
    Apr 2011
    GREENVILLE, SC
    Default 12V ADAPTER
    looks like Piston and i think alike....
    i have 4 on my '09 RS/SE5...
    2 in the dash: radar detector & phone, 1 in the frunk: just in case i need it, and 1 under the seat for the GPS...
    here are some pix:
    Dan P
    Easley, SC
    SPYD3R
    Imperial, PA
    I have a 2011 RS with the outlet in the OEM trunk location. After checking the outlet I found that it is switched. I would like to use this to plug in my battery tender. Can anyone tell me which fuse is used and can I move it so that the outlet is always hot.
    Frank
    Jan 2013
    Quote Originally Posted by frankm View Post
    Frank
    At a guess...
    If you open the frunk lid theres a black plastic cover above the top of the frunk. Remove that by pulling it. Behind that on the right as you look at the front of the spyder is a fuse box. Remove the cover of the fuse box and it has a diagram of the fuses. There will be 2 spare auxillary points, one switched, one not. My guess is your outlet has been wired to the switched one - you'll probably find that has a fuse while the nonswitched one doesn't. From there you'll need to work out how to switch the connection over to the unswitched one, and the fuse of course. Just be careful if you try and put the fuse box out to look at the connections because the sides are very fragile.
    Again I say this is a guess because its switched as everyone seems to wire these up differently.
    Imperial, PA
    Thanks for the reply, Piston. After doing a ride today and checking and topping off the oil after returning, I took a look at the fuse box and receptacle. Not being an electrician, my knowledge of it is that it hurts when you stick your finger in a socket, I decided to leave well enough alone and attach the battery tender to the terminals under the seat. I can get to them easy enough and if the weather holds I can get the tender pigtail attached to the terminals.
    Frank
    Oct 2014
    Georgia
    Thumbs up
    Radar detector...I hadn't thought of one of those.....what brand? where'd you purchase? details on mounting(close up pics)? TIA
    Quote Originally Posted by SPYD3R View Post
    here are some pix:
    Dan P
    Easley, SC
    SPYD3R
    Apr 2011
    GREENVILLE, SC
    Default HOW 2 MOUNT
    Quote Originally Posted by Johmkliff View Post
    HOW 2 MOUNT....?
    let me tell u i re-purpose lots of things...
    i took a plastic pants hanger: SAM_1001.jpg cut the end 'clips' off...
    then i use industrial glue to glue it to the bottom of the radar detector: SAM_1003.jpg...
    then once dried, i clip the assembly onto the center of my dash: SAM_1002.jpg...
    O.BTW - these clips work well for sealing potato chip bags, and other such items....
    as for which brand of detector, and where purchased... it matters not - it's all about choices...
    however, i've been searching the web for a BLUE TOOTH RADAR DETECTOR... so if any1 knows where, or if, these are available, please speak up....
    Dan P
    Easley, SC
    SPYDER
    Nov 2014
    TriCities, WA
    Spyd3r in light of the fact that your radar detector is pointing down rather than straight any issues detecting?
