Results 1 to 13 of 13
    Bryant, Arkansas
    Default Possible Solution to Sun Glare on GPS
    After reading several complaints about sun glare on GPS Screens, i tried something and while it is not perfect, it helps quite a bit.
    Get a small sheet of dark window tint and apply it to your GPS Screen, and turn the GPS brightness all the way up.
    It is not perfect but it works. (as far as i can tell)
    Cruzr Joe
    Default Reducing Glare?
    Here's how to fix the problem...
    Aug 2013
    SF Bay Area
    2021 F3 Ltd , Magna Red
    MOgang Member
    Mar 2012
    Cuba, MO
    Default Glarestomper
    I agree. Glare stomper is a great product.
    Dec 2008
    Syracuse, NY
    I've tried about 5 different things, including the glare stomper, and the thing that Bob D. posted (for a smaller video camera of course), and nothing seems to really work for me. I've also repositioned the gps. When the sun is at a certain angle to the gps nothing seems to help much. But, if I had to choose one thing that helped the most, it would be the video camera shroud.
    Apr 2014
    Arizona
    I wish someone made a glare stomper for the whole dashboard on the RT.
    Nov 2014
    TriCities, WA
    Quote Originally Posted by ArachnidRyder View Post
    Ask your wife, I'm sure that she could whip one out if you gave her an idea.
    Quote Originally Posted by wyliec View Post
    Like especially when it's directly behind you! Even in that situation I've found the anti-glare screen protector on my tablet GPS keeps the screen readable.
    SoFlo
    Cruzr Joe
    I seldom use the GPS, but have had glare issues with it. Most times tilting did cure the concern, other times not.
    So I need to ask, when you tinted your GPS screen, did you use permanent tint or the type that stays in place via I think static cling?
    PK
    The problem of glare on the entire dash, is often reflected light coming off of your handlebars... Try some black tape in strategic locations, and see if it helps.
    (Found the Glare Stompers on E-bay for a touch over $13...)
    http://www.ebay.com/itm/Case-Mount-G...item3cf395456f
    Bryant, Arkansas
    PK
    Static cling in case it don't work
    Cruzr Joe
    SoFlo
    Cruzr Joe
    Expected that but wanted to be sure.
    PK
    Mar 2012
    Florida Space Coast
    Interesting. I might try the glare stomper. There have been times when we've been riding two up and I can't see the GPS screen my wife looks over my shoulder and tells me what it says.
