Results 1 to 9 of 9
Thread: Backrest mod
    Jun 2014
    Elko Nevada
    Default Backrest mod
    Made my own under seat mount that allows me to easily remove the backrest when riding with a passenger. Then made a few minor changes to the backrest it's self so I can just slide into the mount.
    Active Member rays hell's Avatar
    Hiram Ga.
    Default Support
    Looks very nice. Can you tell us what you used for the slide?
    Or did you fabricate it yourself?
    Jun 2014
    Elko Nevada
    I went to Home Depot and purchased 2' of metal as shown in the pic below. I measured from underneath the seat to the opening which was roughly 5 1/2 inches. I cut two piece of the metal and welded them together making a sleeve for the backrest arm to slide into. Took another flat piece of metal and used a hand grinder to cut it 4" in length and 1 1/2 wide as the arm for the backrest. It was necessary after drilling the mounting holes to bend this piece slightly back so the backrest stands up straight and allows a comfortable position against the back.
    If you look at the previous pics you can see I used a piece of flat metal also as a way to attach it to the seat.
    Hope this is clear (as mud lol).
    May 2015
    Girard, il
    Slick job but is your backrest secured to the slide in mount? How?
    Default Way to go....
    nice up grade. Always works well when custom made...
    Default BACKREST
    ...................I love D.I.Y.'ers ......Mike
    Jun 2014
    Wickes, Arkansas
    Default Backrest
    Me to
    Jun 2014
    Elko Nevada
    Rottie, the sleeve is permanently mounted on the cross bar I mounted under the seat. The Backrest arm just slides right into the sleeve and is a solid mount.
