Page 8 of 76 FirstFirst ... 4567891011121858 ... LastLast
Results 176 to 200 of 1900
  1. #176
    Feb 2020
    N. Wilkesboro, NC
    Swapped out my stock seat for a Comfort seat on my '18. About to install foam grips. I'll ride tomorrow after church.
  2. #177
    Mar 2015
    forrest above Reno, Nv
    Ordered Speed Bleeders for the 3 calipers.
    Lew L
    2014 RTS , Circuit Yellow
  3. #178
    Dec 2013
    Yesterday - Rode it!
    Today - gonna ryde it some more!!
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
  4. #179
    Mar 2018
    north georgia
    installed ultimate mid rider seat on my 2017 rt, getting ready for a sturgis and yellowstone run
  5. #180
    Dec 2019
    Western Colorado
    I did the BRP Xenon Headlight COnversion and the RIVCO Handle Bar Riser Kit on my 2012 Spyder RS-S, and I was able to get the trike blown apart after skinning, and get it back together. You have to stretch the cable out, and the headlight job demanded a frunk removal and console removal too. Its really not that bad. The instructions they sent are spot on, the even explain the harnesses, and I learned a TON about my trike today.
    The new Handle bars are so much better. I left the bars wider with the kit, you can trim it to length, but I wanted to bring the bar back and have a longer bar, mission accomplished, I can ride it with my bum shoulder all day now, and now leaning on the bar anymore.
    2012 RS-S , Baja Ron Plug Wire Kit and NGK Iridium Plugs Grey and Black
  6. #181
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Lew L View Post
    Lew L
    I also ordered the Speed Bleeders for all 4 ports.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
  7. #182
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    I rode my 2018 RTL today for the first time this year!! Our temps in the Omaha area reached 74 degrees - however very, very windy??? but it felt good to get out and feel the air...
    BIG F
  8. #183
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by WDAVEY View Post
    Today I put the first scratch in my 2019 RTL. Pulling into my shed, standing on the footboards so I could look over the windshield and get the front really close to the back shed wall. Got close to the wall, right foot missed the brake pedal (note to self, get the bigger pedal!). Hit the wall at about 1 mph. About a 2" long scratch in the "beak" of the frunk. NOW I have a 2X4 on the floor so the bike will stop before it hits the wall! Just ordered touch up point from ScratchesHappen.
    Put a BRA over it and call it good.
    Tag-Along trailer
    Garmin 396 LM GPS
    New Banshee AGM
  9. #184
    Aug 2012
    Bellevue, NE
    Unfortunately NOTHING????? Our weather turned crappy again so my Spyder is "resting"...
    BIG F
  10. #185
    Nov 2017
    San Francisco Bay area
    Added a 2 usb port voltmeter combo and a clock.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    2015 RTL , Yes Pearl White
  11. #186
    Mar 2020
    Santa Clara ca.
    Ordered Bajaron sway bar and magnetic drain plugs.
  12. #187
    Active Member iridenow's Avatar
    Sep 2019
    Phoenix, AZ
    Replace the tiny brake with a full sized brake.
    Fought and fought with the foam grips until they wiped me out. I took the end cap off, used the hand sanitizer liberally, but was unable to get the grip over the end of the hand grip to where i would be able to twist and turn it to get it on.
    Fred is a 2010 RT SM5 - Sold.
    I am not a mechanic. When I have a tool in my hand, 911 needs to be on Standby.
  13. #188
    Dec 2019
    Western Colorado
    I named my Spyder RS-S today, her name is "Charlotte", and the car port? Yep you guessed it, Charlotte's Web...the Triumph is now Wilbur....
    I also tested my Air Hawk Pro Hand Held COmpressor I picked up at Ace Hardware (it is also.....Available at Walmart I am told).
    It gives me EXACT 17 pound front tire fills. I can do 15, but I do 17 as unscrewing the stem filler can cause a pound or two of pressure loss. I also put in the highest weight as I will be doing passenger riding too.....rear tire is a perfect 30 pound fill.
    Get this tool, its really handy for bikes and trikes, and bicycles too...not so much on truck tires. I did my economy car tires today too. It auto shuts down when it reaches your set pressure. I love this tool.
  14. #189
    Not on a , but started up the John Deere for the first time this year. I mowed the grass.
    Dec 2013
    So you DID get some riding done today!?!
  16. #191
    Yes, and it was a blast. I always enjoy mowing the grass.
    Danbury Connecticut
    I got mine registered.
    3 hours in the waiting line, and another 30 minutes to make the transaction once I got to the window.
    I think I'll write a science fiction/action movie script.
    I'll call it "Escape From The DMV"
    IBA #47122
    2020 RT Limited Asphalt Grey
  18. #193
    Nov 2016
    Palm Coast, Florida
    It's Daytona Bike Week so I rode the Ormond scenic loop, must have seen at least 20 other spyders.
  19. #194
    Aug 2012
    Bellevue, NE
    Here is what I did to my Spyder...
    I looked at my Spyder in the storage garage (AGAIN?)!!!!!!!!! weather is still yucky - matter of fact the weatherman is saying snow this weekend??????????? :-(
    BIG F
  20. #195
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    Ordered a gel pad from Motorcycle Dave
  21. #196
    Dec 2016
    Gold Coast, Australia
    Fitted my driving lights
  22. #197
    Very Active Member h0gr1der's Avatar
    Apr 2019
    USA
    Finished installing my upgrade lights. Put in LED 360° headlights and fog lights, as well as those fancy progressive front fender turn signals. Headlights are 9005 form factor, specs are 6000K color, 70W/7000LM, DC 12V. Fog lights are H9 form factor, with the same specs. They are extremely bright.
    Kinda nekkid. Best way to get that left fog lamp cover. To all those that accomplished this without taking the frunk off; I salute you! This is a great time to clean the radiators.
    Back side of frunk. 2 person job to remove and install. I had the comms cable on one grommet (1 USB and 1 3.5mm jack) and a battery tender that didn't get removed. Had to expedite the removal on the fly. Poke the grommet out with a screwdriver and remove the battery tender harness before starting.
    There's that booger, left fog light cover. It was hard to remove and install even with the frunk on the ground. The air intake pipe gets in the way, took a fair bit of wiggling to get it past the bulb base both in and out. A little silicone grease makes getting the air hose installed much easier.
    Here's my lifting setup. Cheapo Harbor Freight jack, some small jack stands, and a ramp for the rear. Solid as a rock. The jack doesn't have an easy lower feature, but if you are familiar with floor jacks it isn't a problem. Just have to remember to unlock the safety before lowering. It's so similar to a normal floor jack I forgot a couple of times.
    h0gr1der
    2018 RT Limited Blue/Chrome SE6 *Tri-Axis Bars*Adjustable Driver Backrest*175/55R15 Vredestein Front, 205/60R15 Vredestein Rear Tires*Baja Ron Front Spring Pre-Load Adjusters*Misty Mountain Sheepskin seat cover*Centramatic balancers *Garmin Zumo 595LM GPS*KOTT Grills*BajaRon swaybar*SpyderPops Alignment*Missing Belt guard*Magnetic Mirrors*Custom Rear Adjustable Shock*360° LED Headlights & Foglights*Progressive front fender turn signals
    States Visited on Less than 4 wheels.
  23. #198
    Jun 2017
    Rapid City, SD
    Put over 200 miles on the odometer since this weekend and gonna put some more on tomorrow. Lots of people out doing wind therapy while the weather’s nice.
    HE>I
    2017 RT , Asphalt Grey
  24. #199
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Did about a 200 mile circular trip from VA to MD to WV and then back home, mostly the back roads.
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
  25. #200
    Mar 2015
    Angry Very expensive piece of plastic.
    Fixed the broken mirror top plastic cover. One of the tabs broke a few weeks ago and the top satin/ chrome piece was loose. The 2 unbroken tabs has some flex in them but the broken one didn't. After gluing the tab back together and giving it a 24 hr cure, I cut away the little, tiny gusset ( plastic) and now the tab flexes just a bit like the 2 others. Hope it all works and stays together as this silly piece of plastic costs $104. Looked at three suppliers and they were the same price. After seeing that ridiculous price---- I had to find a way to fix it.
    Lew L
