High RPM
Is it normal for my RT SE6 to turn 4,000 RPM when cruising on the highway in 6th gear? That's a lot higher RPM than I'm used to on previous bikes.
Pam
Pam
Pam,
When you are in sixth-gear and cruising at highway speeds (60mph+) the 1330 engine will run at higher rpm's than most cruiser motorcycles. Nothing to worry about. It is quite normal. Rotax motors are designed for higher rpm's.
Ride often, safe, and aware!
Illinois Boy
