Results 1 to 11 of 11
Thread: Side grills
    Active Member Tatonka's Avatar
    Jan 2018
    North Carolina
    Default Side grills
    Watching a you tube video re custom side replacement grills....looked at the machine and the sides are different ..left side has black grill and bottom is solid panel...right side is open..top and bottom....is this correct...have changes been made over model years ?
    Faribault, MN
    Yes. 2014 and up include a right side grill and block-off plate. Same part (Part #705004803 Right Side vent ) can be used to even up the appearance of '13's and before.
    Many have touched on how to do this and properly... I used Rob's Mods and Farkles example.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Feb 2017
    Here's similar approach to the missing grill problem. My wife's 2012 RT Limited suffered the same lack of symmetry not to mention the roasted right foot dilemma but we approached the issue differently.
    Her Spyder has Seal floorboards and we found the solution (actually, a solution) by installing the insulated block-off panel offered by Lamonster Garage to close the upper opening. We left the lower opening immediately in front of the floorboards in DGoebel's second photo - open. We also modified the panels below and to the rear of the radiator to allow hot air to escape. Engine temperature gauge needle remains in the center of the dial and her right foot no longer roasts. Works for us although the right panel is solid black rather than the nice mesh grille style on the left side.
    The were built that way through 2013. Many have taken a stealth trip to the dealer to inspect other machines--to check if they were really missing a right side grill cover.
    I was one of those fooled in 2008.
    Aug 2015
    Afton Tn.
    I bought a box of spider parts off eBay. A left Grill was in the parts. I put it on the right side with zip ties upside down and you cannot tell the difference looks Factory
    Dec 2017
    Ontario
    Quote Originally Posted by CMA/IBA_rider View Post
    my grill
    Quote Originally Posted by Tatonka View Post
    Here's what I did for the 2013 RT I had to balance the look and block the heat from the upper vent that cooked my foot when I had it on the highway peg.
    http://www.spyderlovers.com/forums/s...ighlight=grill
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    So this part will also fit a 2010 RT as well?
    2010 RT SE5 , Black
    Jul 2013
    Vestaburg Michigan
    Thumbs up
    I used the same grill on my 2013. But I attached an old mud flap to the inside of the grill portion, so the appearance was the same using Velcro. Removed bottom skid plate and opens up pan behind fan at the bottom. If I ride in really hot weather (100+) I cantemove it. So after install, temp stays just below half mark and no hot right foot!
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by rtlimited View Post
    my grill
    Where did you get these?
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Faribault, MN
    Quote Originally Posted by Eviltwin View Post
    EvilTwin, I believe so, I've seen it done on '13's and '12's. The part is about $21.00 from a dealer and is plastic and easily adjusted so it should. I did remove part of the bottom plate under the bike, and cut extra radiator outflow vent holes in the bottom of the area covered by the block off plate. some just cut part of the bottom of the block off plate to allow outflow there as well.
    Safe Rides,
    IBA 70020
