Page 9 of 78 FirstFirst ... 56789101112131959 ... LastLast
Results 201 to 225 of 1932
  1. #201
    Active Member triplethreat's Avatar
    Feb 2020
    "Murvil", TN
    I spent a good chunk of time looking for and finally finding the Accessory wiring in the front of my '19 RTL. I finally discovered it after taking the battery out and it was right behind the rubber plug in the left side of the frunk. After finding it, I ran the power cable that came with my Zumo XT from the accessory wiring terminals back and up to where the switches are for the fog lights and the grip heaters. I removed one of the blanks and brought the wiring up through there and up to my GPS center mounted base. All I can say is that working on the Spyder and doing stuff like this is a b!tch!.....but it's done and working.
  2. #202
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    with this virus lockdown, all I do with my Spyder is LOOK AT IT????????????? :-(
    BIG F
  3. #203
    Jan 2015
    southern WI
    The excitement of the day just might be opening up my new half cover for the RT, the full cover for the Ryker, and installing a new belt tensioner.......
    2016 RTS , Pearl White
  4. #204
    Linden, CA
    Quote Originally Posted by Big F View Post
    BIG F
    Mine is just sitting in the garage getting dusty
  5. #205
    Sebring, FL
    Funny you should make the 'dusty' comment, mine too has dust, I gotta wipe it own so can collect more dust.
  6. #206
    Nov 2018
    Denver, Colorado
    Rode it to work!
  7. #207
    Clinton, MS
    If you were out riding over here it would come back covered in pollen..........
  8. #208
    Active Member redrazor's Avatar
    Mar 2020
    Martinez, CA
    Just ordered the anti-sway bar for my 2014 RTL from Bajaron! Had great chat with him on cell phone. Super sharp guy! Might go for a ride today since we have sunshine. Keeping a Fronk full of non perishable groceries in case I'm questioned about being "out-and-about". "Just coming back from the necessary grocery stock-up".
  9. #209
    Feb 2020
    "Murvil", TN
    I guess it varies from state to state, but there is absolutely nothing against any Executive order about going riding in TN. In fact, they are encouraging people to get out and walk, exercise, etc, but keep your 6' distance from each other. Every time we ride, we pack a cooler with some water/drinks and a few snacks and just go out and enjoy the beautiful weather and the gorgeous roads...without making contact with others, even when we stop to take a break.
  10. #210
    Feb 2020
    "Murvil", TN
    Quote Originally Posted by redrazor View Post
    If you ride even a little faster than a snail's pace, you will notice a huge improvement in the handling and cornering with the sway bar. It is night and day different, and the harder you push it, the better it performs. Win - Win!
  11. #211
    Mar 2015
    forrest above Reno, Nv
    Thumbs down More poor design from BRP
    Quote Originally Posted by Lew L View Post
    Fixed the broken mirror top plastic cover. One of the tabs broke a few weeks ago and the top satin/ chrome piece was loose. The 2 unbroken tabs has some flex in them but the broken one didn't. After gluing the tab back together and giving it a 24 hr cure, I cut away the little, tiny gusset ( plastic) and now the tab flexes just a bit like the 2 others. Hope it all works and stays together as this silly piece of plastic costs $104. Looked at three suppliers and they were the same price. After seeing that ridiculous price---- I had to find a way to fix it.
    Lew L
    UPDATE:
    After fixing the above, two more problems cropped up:
    1. The trickled fenderz, sequential light I recently installed weren't right so I dove into them also. A loose connection at the mirror tap . If you have these the connector MUST be pushed together REALLY hard or it will come loose. I taped it also.
    2. As in the first fix, a tab has broken off but this time on the bottom of the mirror. Right where you strike to to remove the mirror ( if you don't have the Magic mirror magnets) I'm sure it broke a while back when I was hitting the mirror to remove it ( what a poor design in the first place). Another $100+ part of brittle plastic.
    2014 RTS , Circuit Yellow
  12. #212
    Active Member scarecrow's Avatar
    largo, florida
    Added Air vents to my 14RTS
    2014 RTS , Cognac
  13. #213
    Wa.
    Waxed my spyder rtl this afternoon. So nice an shiny now, still looks like it just came off the showroom floor.
  14. #214
    Aug 2012
    Bellevue, NE
    actually it was yesterday! what I did to my Spyder was get on and ride!!!! Our weather was fantastic (mid 80's) and I got on my Spyder and rode over to Oakland, Iowa and back.. Made my mindset a bit better as I'm having extreme "cabin fever" with this virus BS!!!
    BIG F
  15. #215
    Danbury Connecticut
    I received my new UltraGuard half cover. The Nelson Rigg half cover for my 2014 doesn't fit the new 2020 RT Limited.
    IBA #47122
    2020 RT Limited Asphalt Grey
  16. #216
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    We mobile self-isolated the last 2 days. Went for a ride in the hinterlands of the Missouri/Arkansas/Oklahoma Ozarks. Didn't see a soul in 5 hours of riding yesterday from the time we left Anderson, MO until we got to Grove OK, about 10 miles from home. Today we went to Indigo Sky Casino near Seneca MO. Gloria had previously rode a VW trike with an automatic transmission for 10 years, never piloted either of the Goldwing trikes we had, and hasn't hasn't much seat time in the front on the Spyder. With this Stay-At-Home order in Missouri (outdoor activities are allowed as long as the 6' and less than 10 people rule is followed) the casino is empty, and there are huge parking lots for her in which to practice. She even got up to 4th gear for the first time today. Another practice or two for confidence building and we'll hit the real roads. A few times on mostly empty roads and I'll lead or follow her on the Bonneville while she solos.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: AMA Charter Life Member, MRF, FORR Life Member Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    2018 RT Limited , Got one, on, then off then on until Gloria decides if she likes it or not. blue
  17. #217
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
  18. #218
    Very Active Member Pandy's Avatar
    Mar 2011
    Lake Wylie South Carolina
    Removed the RH tupperware to try and isolate my air suspension leak. Next stop is trunk removal to expose entire system. Pump is D.O.A. so a direct connection will be plumbed unless there is a hole in the airbag.
    2011 RTS 2006 Yamaha Morphous
    2011 RTS , Orbital Blue
  19. #219
    Mar 2018
    Ontario ,way up north
    I connected direct to the battery . In the winter i use the same plug for the battery tender.
    2018 RTL , dark blue
  20. #220
    Mar 2013
    Marion, Arkansas
    Couple of days ago I added and LED bumpskid to my 2017 F3 Limited. Can't have enough lights either front or rear. I bought the LED bumpskid from a Spyderlovers member who had bought it from Tricled but never installed it. The install was about a 5 on the scale of difficulty as you have to drill holes and have to be pretty careful when drilling.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
  21. #221
    Sep 2018
    Australia
    Default Backrest report.
    Fitted a BRP drivers backrest to wifes F3. Super comfy Must mention the ordinary fitment of the mounting bracket though.Had to ream out the bolt hold that locks the bracket down, it was miles out.Also ended up packing blocks of wood and plywood around the bracket to take out the excessive play it gave the backrest.Downright disconcerting having the thing flexing back and forth and twisting sideways whilst riding.Big ''0'' for the mounting of the thing especially for the price paid.
  22. #222
    Oct 2015
    Lynden, WA
    Reinstalled the tupperware from yesterday's Clutch work. Completed an Oil and Filter change, Pulled the rear caliper to check the brake pads (ugh), Inspected the front brake pads (yeh). Noted the need for new front tires, Ordered more new parts and tools. Fun Day
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  23. #223
    Dec 2014
    S.E. Michigan
    A couple of days ago, but I removed the rust on the back rack of my 2016 RT-L. One spot where the chrome plating is completely gone I "fixed" with shiny nail polish. Next project will be a louder horn.
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
  24. #224
    Feb 2019
    Portland, Oregon
    Sandeejs....Horns like these? Loud and car like, but I don't know if there's that kind of space in an RT.
  25. #225
    Mar 2019
    NEBRASKA
    I have a pair of mini floorboards from Web Boards coming. Installed USB in center console, phone holder, Spyderzone zippered bag inserts and drink2 go carriers and foam handlebar covers. Looking for armrests and backrest and trailer hitch/wiring.
    2012 RTL 14 RTS , Pearl White @ Pearl White
