Page 13 of 78 FirstFirst ... 3910111213141516172363 ... LastLast
Results 301 to 325 of 1929
  1. #301
    What did I do to my Spyder Today? Rode it!!
    Put a couple of hundred miles on the new battery (had to retire the original after it failed completely it was only 7 years & 5 months old! ) and this weekend was our first (local) weekend out of our State's 'group gatherings of 10 persons max' lock-down, so a fewof us got together & cruised down to the mouth of Australia's largest river, the Murray, to have fish'n chips on the beach!
    Great day, great ryde, -2°C start, but the sun fairly quickly burned away the mist & frost, & from there on in it stayed clear, so the temps eventually hit a max of 10°C, which made for a clear, fine, and bloody brilliant day!
  2. #302
    May 2020
    Walker, LA
    Unfortunately I could only make sure she was covered securely in preparation for Cristobal. Then watch it rain through the window, longing to go for a ryde!
  3. #303
    Apr 2020
    Windsor-Essex Ontario,Canada
    Put my Ultimate Seat on. Well built and comfortable for both me and wife put some miles on it
    https://ultimateseats.ca/can-am-spyder-accessories
    Happy Wife Happy Life !
    2012 RS S SE5 , Grey and Black
  4. #304
    Mar 2013
    I did the rain dance (washed it)last night. Going for ride soon, so it should rain.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
  5. #305
    Oct 2019
    Sweden
    Just got back from a longer trip 500km (310 miles) on my Ryker, just to find that finally my x-grip has arrived on the mail. I installed it right away, cant wait to give it a good try!
    The OEM tank bag is OK, but for the phone it just doesnt cut it. The charging Cable does not fit, and you have to take the Eyes too far from the road to look at the GPS on the phone.
  6. #306
    Sebring, FL
    worked many hours trying to install Big Bike Parts back rest on my 20 RTL, work, work, and no success. Got to the install of the L metal frame L piece that is to suppoort the back rest, and just seems no way to fit that L bend on to the RT for final step install. Looks like I'll be taking it to the dealer see if they can figure it out, I have to take it in for the fitment recall, just get it done then. Talk about frustration. Yes, I called accessories.net, they gave me instructions to pull up on the under pan and the L metal support will slide right in, that didn't happen.
  7. #307
    Feb 2020
    N. Wilkesboro, NC
    You have to loosen up the (2) bolts (one on each side parallel w/the channel for the L bracket) pretty far to fit the L bracket in there.
  8. #308
    Invalid Emails
    Feb 2020
    Splendora TX
    Dressed it up!!!
  9. #309
    Feb 2020
    N. Wilkesboro, NC
    Yesterday, I swapped back from the Comfort seat to the stock seat and today I'm going to install one of those trunk organizers. Other than getting a new mounting bracket for the Utopia backrest that fits the stock seat, I'm not doing anything else to this bike. Decided to get smart and change plans. I have about 1.5 years left on my Honda (cage) lease then I'm going to turn it in, but a cheap beater (I'm now working from home and drive about 15 miles per week) and buy a new F3 (T or L) or a new 2020+ RT (base model). I'm done sinking money into this.
    HAGO!
  10. #310
    Sebring, FL
    Thanks Monk, believe me, I have removed the two 13 mm bolts, loosened the other two and lifted mightily, nothing seems to work, noting gives. The recall has not been done on the refit recall, maybe that's the problem. I even removed the driver's seat, no joy there either. So tomorrow I put it all back together so I can ride.
  11. #311
    Jun 2020
    Ashburn, Va
    I finally got my plates! Too bad the Spyder is in the shop. I've had it for almost 3 weeks and only was able to go up and down my street a couple times.
  12. #312
    Active Member Stache's Avatar
    Apr 2020
    Flatrock, NL, CA
    Installed CANAMSPYDERACCESSORIES hitch and wiring harness. Flawless fit. Working on the showchrome ryder backrest. Mounting bracket fit is giving me issues.
    MWO (Ret'd) SJ Barnes
    ‘20 RTL Stone Grey
    named Britannia in honour of EE Doc Smith’s
    Grey Lensman’s ship.
    Farkles:
    Bestem Carplay
    canamsypderaccessories hitch and wiring harness,
    showchrome trunk rack,
    12v AND dual USB direct to battery in the frunk,
    dual USB switched in the blank console switch spot (parasites the power off the seat heater switch),
    frunk lid organizer,
    trunk organizer,
    showchrome rider backrest,
    ryder and passenger cup holders,
    ram mount for the iPad mini I use for GPS
    quadlock phone mount
    Nautilus horn
    Data blocker on the glove box USB
    Big Bike Parts highway pegs
    Spyderzone dash pouch
    Convex mirrors
    ‘20 Ryker 900 (my wife’s ryde)
    Farkles
    Slingmods fwd/rev ‘suicide shifter’
    frunk organizer
    dual horn
    Max mount
    Rear seat with tall back rest (not mounted)
    Ryder backrest (not mounted)
    Side bag
    Top bag
    top bag makes a good backrest. Will swap on the rear seat if she ever wants to 2up
    2020 RT Limited , Stone Gray
  13. #313
    Sebring, FL
    Re post 306, hallelujah, after persevering, I finally got that aftermarket back rest installed, it was me, I was doing something wrong. Glad I persevered 'cause I like that backrest.
  14. #314
    Apr 2020
    Flatrock, NL, CA
    Was it the mounting bracket? How did you get it in the slot?
    ‘20 RTL Stone Grey
    Farkles:
    Bestem Carplay
    trunk organizer,
    Nautilus horn
    Convex mirrors
    Farkles
    frunk organizer
    dual horn
    Max mount
    Side bag
    Top bag
  15. #315
    Sebring, FL
    It was the L shaped mounting bracket. I just kept fiddling, placed it in the slot and gave it a mighty lift one last time in the middle of the plte and and the bike mounting bracket just sort slid into place. I think my problem was trying to make it slide into the the very bottom instead of the 'top' just under the round opening where the fender washer goes and the bolt fastener goes through to thread into the bike mounting bracket. I completely removed the two 13mm plate bolts toward the front, and loosened those two toward the rear of the plate so the plate would budge enough. Happy I did not 'give up' and make the dealer service department appointment. those people are not cheap.
  16. #316
    Apr 2020
    Flatrock, NL, CA
    ‘20 RTL Stone Grey
    Farkles:
    Bestem Carplay
    trunk organizer,
    Nautilus horn
    Convex mirrors
    Farkles
    frunk organizer
    dual horn
    Max mount
    Side bag
    Top bag
  17. #317
    Sebring, FL
    Pleasure, always like to share if I have the answer. I hate to admit I spent a lot of time figuring this out 'cause there was no clear cut advice on 'how to' get this thing to slide into place. It may have worked first time for some folks, but not me. :>)
  18. #318
    Mar 2015
    forrest above Reno, Nv
    Working on a drinking system with my wife. She didn't want to use a camel back. We'll use here 32 oz cooler cup and a piece of clear tube with a camel back valve system. And of course a magnetic hose holder for her jacket. We'll see------.
    Lew L
    2014 RTS , Circuit Yellow
  19. #319
    Active Member Snakeyes's Avatar
    Nov 2019
    SE Pennsylvania
    I installed the Baja Ron sway bar and went for a 70 mile ride - What a difference!
    2019 RTL Asphalt Gray
    2019 RT Limited , Asphalt Grey
  20. #320
    Jan 2015
    southern WI
    Nothing to mine, but I put LED fog and headlights in my wife's new RT. The left fog light kicked my @$$ for a little bit.
    2016 RTS , Pearl White
  21. #321
    Jun 2020
    ottawa valley canada
    Quote Originally Posted by Hammer View Post
    how do you like your seat? I'm thinking of getting one, did you get the back rest? and the fuel door?
    tks
    stewart
  22. #322
    Wa.
    Installed the Canamspyderaccessories Floating Pegs yesterday morning. Really easy to install an look good. Now need to go on a good ride to see how they help with comfort of my legs.
  23. #323
    Wa.
    Today installed the RT Front Grills in stainless steel. One is the RT design an the other is a Spyder design from CANAMSPYDERACCESSORIES. He was so nice to split up 2 sets so I could have one of each for my spyder.
    All so installed the Dual USB charger in the empty spot in the middle of the switches below the handle bar. Switch from CANAMSPYDERACCESSORIES
    And put on a Riders Drink Holder from CANAMSPYDERACCESSORIES
  24. #324
    Apr 2020
    Flatrock, NL, CA
    Quote Originally Posted by MONK View Post
    Got min in, but I had to be a little forceful with it. When in I found the screw wouldn’t reach with both fender washer and lock washer. Used just the fender washer with some loctite on the screw.
    ‘20 RTL Stone Grey
    Farkles:
    Bestem Carplay
    trunk organizer,
    Nautilus horn
    Convex mirrors
    Farkles
    frunk organizer
    dual horn
    Max mount
    Side bag
    Top bag
  25. #325
    Apr 2020
    Flatrock, NL, CA
    Mounted the backrest, added the hitch ball to the hitch I mounted earlier, re-attached the wire harness using black zap straps. (The yellow ones I used (all I had when I originally installed it) were ugly against the black hitch.
    ‘20 RTL Stone Grey
    Farkles:
    Bestem Carplay
    trunk organizer,
    Nautilus horn
    Convex mirrors
    Farkles
    frunk organizer
    dual horn
    Max mount
    Side bag
    Top bag
