Results 1 to 11 of 11
    Oct 2020
    Fort Mill SC
    Default self cancelling turn signals
    Looking to buy a 2018 F3T does it have self cancelling turn signals. Can't find the info in specs. Thanks
    Feb 2020
    N. Wilkesboro, NC
    It does. If you make a fairly sharp turn, it will cancel right away. If you only make a sweeping turn, it will self cancel after 30 seconds.
    Pg, 23-24 of the operator's guide.
    I get a bad "Server Error in '/' Application." notice with this one.
    As do I?!
    I figured out sometime ago for both parts and manuals documents you must go to the top page and then drill down to the desired year and model and language. http://www.operatorsguides.brp.com. Links direct to the documents or parts pages don't work, but usually they take you to the top page. I don't know why this one doesn't.
    Mac is correct. I thought I might be able to get exactly to the '18 F3 there but it didn't work.
    Nov 2012
    North Las Vegas, NV
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Yep, like I said that link takes you to the Operator's Guides home page, not the document itself.
    Jun 2019
    Deltona FL
    Have to turn handlebars at least 30 degrees to activate.......
    Active Member Ready2Retire's Avatar
    May 2020
    Henderson NV
    If you push in on the centered turn signal switch (not moving it left or right) it will cancel the turn signal. As has been said, a sharper turn will auto cancel the turn signal, but a sweeping turn will not. The above method is also useful when changing lanes as you don't want to look like the "India Delta 10 Tango" ryding with your turn signal on for no reason for 30 seconds...
    John
    2018 Silverado LTZ 3500HD CC LB 4X4 DRW Duramax/Allison
    2019 Grand Design Momentum 381M w/Full Body Paint
    2016 Can Am Spyder F3 Limited Special Series
    MSgt, USAF (Ret)
