Recommend any Blocks for front wheels in trailer?
Hi folks, I just bought an enclosed trailer.
Is anyone aware of a couple of blocks that I can mount to the floor in front of the tires that would probably keep the Spyder from moving from side to side?
Thanks in advance.
Thanks in advance.
If your main concern is side to side ..... what will work fine is...., use a small piece of plywood then screw two short pieces of 2" X 2" to the front and one side of the plywood .... then when you load your Spyder roll it onto the plywood pieces and screw them to the floor. ... I use the Rachet over the tire method to keep the Spyder from moving , so this is an easy way of preventing movement. .... some folks take a 1/2 hr. to an hour tying their Spyders down .... I do it in about 10 minutes ..... good luck ..... Mike
IF you can find a set of these Spyder Super clamps for sale, get them. Once and awhile a set is for sale on here and well worth it.
They no longer make these.
https://www.etrailer.com/s.aspx?qry=wheel+chocks Try these guys, they are not cheep, you can probably find some thing cheaper, but it's a start!
Someone on this site has a pair for sale right now. https://www.spyderlovers.com/forums/...k-kit-for-sale
Not cheap, but I used two Condor motorcycle chocks. Very heavy duty and nice looking. I already had one from my Harley days so I only had to buy one additional. Position the Spyder in your trailer to achieve desired tongue weight of 10-12% of the trailer total loaded. Mark the exact location where the front tires need to stop.
Thanks to all that answered.
I went with a nice pair from etrailer!
If you need wheel chocks WalMart sells them dirt cheap! that is where I got mine. bolted them to the floor of the trailer and have many thousands of miies with the Spyder on the trailer and no issues.
BIG F
