Page 40 of 80 FirstFirst ... 3036373839404142434450 ... LastLast
Results 976 to 1,000 of 1978
  1. #976
    Mar 2021
    Arizona high country
    In preparation for a couple of extended trips coming up I installed the top case rack. Big Bike Parts 41-355BK Tour Trunk Rack (CAN AM F3, Yamaha Star Venture)
    Also installed the LED turn signal bulbs (rear) OXILAM 7507 PY21W BAU15S LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Built-in Load Resistor CANBUS Error Free 2641A 12496 7507AST Bulb Replacement (2PCS). These replaced a previously installed LED light that cause hyper-flash.
    Both items purchased through Amazon Prime.
  2. #977
    Oct 2015
    Lynden, WA
    I bought 2 front tires for my F3T.
    165/60R-15 Vredestein Quatrac SL.
    Hope to install the tires in a few days.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
  3. #978
    Aug 2019
    Stoughton, WI
    Handlebars disassembled as my Helibar V2's arrive today
    2022 RT Sea To Sky
  4. #979
    Dec 2012
    Murphy, NC
    Replaced my front tires with Hankooks and new brakes all around yesterday.
    2020 F3 Ltd
    Spyderpops Bumpskid
  5. #980
    Aug 2019
    Stoughton, WI
    Installed my 2022 F3 Helibars. Can't wait for the weather to get nice enough to try them..
    2022 RT Sea To Sky
  6. #981
    Mar 2021
    Maryland
    Installed Brake pads for the first time, Cleaned and lubed pins. Followed the video at https://www.youtube.com/watch?v=VbfFLIQ_PsU by Mathieu Tech Moto
    I didn't use his Jacking points (which a lot of people will cringe at) but it helped to make my chore a lot easier.
    2020 F3 SE6
    2020 F3 , Black
  7. #982
    Mar 2015
    forrest above Reno, Nv
    Mounted up new driving lights.
    2014 RTS , Circuit Yellow
  8. #983
    Jan 2015
    southern WI
    Finally got around to mounting the base for my Zumo 396 GPS. A much easier task on the '21 RT than it was on the '16 RT
    2016 RTS , Pearl White
  9. #984
    Jan 2021
    northeast pa.
    finally got around to putting my daytona frunk wrap on.. 65 degrees today, but are roads are dirty and crappy.. getting the itch to get her out... cant seem to remove the sideways pic.. lol.. oh well..
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
  10. #985
    Aug 2019
    Stoughton, WI
    Got my Ultimate Position 5 floorboards installed today. Pierre made the install look easier than it was for me. I learned after the first side to take a utility knife and clean the Line-X from around the frame tube hole. The frame bolt pivots around much easier
    2022 RT Sea To Sky
  11. #986
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    Trouble balancing Vredsteins. Anyone else had this problem? My bike shop in VA did a static balance before I left for FL. Got down here for a first ride and had bad shaking above 45. Went out and got a cheap harbor freight bubble balancer and got to almost 75% better. Went to a local tire shop hoping they could fine tune my work and he stated the tires were totally out of round and the weights needed were off the charts. Sent me to a local repair shop. They spent about an hour on them and declared them “balanced”. Rode today and nearly lost my mirrors and fenders as the vibrations were severe. Finally found a CanAm repair shop about an hour away and they stated that the repair shop has put excessive weights in three positions on each wheel. They removed that mess and redid them. Gonna try them out tomorrow and hope that they are finally done right. Geez…
    2014 ST-S Cognac
    2014 ST-S , OEM Yes Cognac
  12. #987
    Oct 2021
    Wichita, KS
    Quote Originally Posted by ARNIE R View Post
    You've got some other problem there if it is taking that much weight. I would suspect there is something wrong with the tire(s).
    Peter Pan has struck again!
  13. #988
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
  14. #989
    Vermont
    I got my spyder inspected today. The spyder passed inspection.
    I have a 2014 RTS-SE6 Cognac.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  15. #990
    Sep 2019
    Reno, NV
    Deanna
    Thank goodness NV doesn’t require such nonsense.
    Is it for smog ?? Braking ??
    2002 BMW 325i - his
  16. #991
    Mar 2017
    Leesburg, VA
    Well, yesterday’s balance did the trick. Was able to hit 101mph (GPS) today and all was good.
    2014 ST-S Cognac
  17. #992
    Vermont
    Quote Originally Posted by Peacekeeper6 View Post
    The state of Vermont requires inspections for motorcycles and cars, TT units. It was for lights, brakes, directionals, and etc.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #993
    Sep 2019
    Reno, NV
    Deanna
    I see. I used to live in NJ and remember having to do that with my car. I'm kinda 50/50 with these type of inspections, because it just seems to be just another money maker for the state.
    Here in NV, cars/trucks HAVE to be smogged, and the fee is nominal. In fact, my friend owns a smog shop and it only costs me $15 and 5 minutes of my time. Luckily, my motorcycle and trike doesn't have to be smogged.
    (I've seen some jalopies on the road that would want me to wish there was some kind of mandatory inspection, LOL).
    2002 BMW 325i - his
  19. #994
    Oct 2015
    Lynden, WA
    Finished an oil change and maintenance inspection on the F3T.
    Now I'm gathering tools and my courage to realign the handle bars as I can't get a laser align until Oct.
    Anyone with experience please chime in.
    David C
    2016 F3T
    Rear IPS Pack Rack
  20. #995
    Feb 2012
    Spring City,Utah
    Rode my Spyder 255 miles for some tacos. Went to Beaver Ut. to Beaver Tacos. Four bikes and 5 people. 3 Spyders. Then we had to go to The Creamery for ice cream. I had French Silk and Bourbon Pecan. Great day to get out and go.P1100310.jpgP1100314.jpgP1100311.jpgP1100317.jpgP1100320.jpg
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  21. #996
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Parked my new Honda Rebel 1100 DCT next to it.
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
  22. #997
    Vermont
    Peacekeeper6:
    What is smogged?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #998
    Peacekeeper6:
    What is smogged?
    Deanna
    I'm pretty sure He's referring to whether your vehicle can pass " clean air " regs. .... luckily they arn't doing this in Vt. .....YET .... Mike
  24. #999
    Jan 2015
    southern WI
    Finally got the parts to finish my GPS base and USB cord install. Now if it would ever get nice out...........
  25. #1000
    Oct 2015
    Lynden, WA
    Had my seat rebuilt, today, by Seth Lamm on a drive in appointment.
    Rode 250 miles home thru light rain and wind to test the seat.
    Its GREAT.
    David C
    2016 F3T
    Rear IPS Pack Rack
