Results 1 to 11 of 11
    Nov 2013
    Oro Valley Arizona
    Default Anyone had the ACS Air compressor replaced?
    Just told yesterday I need a new air compressor for the suspension. It is making a load noise and dissipates as engine warms up. Cost of small pump is $400. Just watched video of installation and was staggered. Must remove all tupper
    ware plus saddle bags, seat top box and rear splashguard. Was told about a week to a week and a half for pump. We will see. anyone had this done?
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Quote Originally Posted by jaherbst View Post
    Jack
    Jack if the dealer is removing that much " tupperware "|, the $ 400 you mention might be the cost of the pump ONLY .... good luck .... Mike
    Jan 2021
    Descanso, CA
    Search for "viair" as the replacement compressor.
    INDIANA, USA
    Default Side Bar
    ....Hello Jack.......
    Just wanted you to know that I did
    forget. I am retired and getting "older". ....
    I Hope you had a 'Wonderful Birthday'.
    You remember the 'Day' of April. .....
    Spyder Forum Friend. .....Little Blue....
    ENJOY YOUR LIFE WITH A SPYDER
    Nov 2013
    Oro Valley Arizona
    You are right Mike. That price was for the pump only. Expecting at least twice that if not more to get it out the door. I watched a video of replacement and it requires complete removal of all tupperware, seat, bags, topboxe etc.
    Jack
    2015 BMW R1200R LC
    Mar 2015
    forrest above Reno, Nv
    Hi Jack,
    My pump failed because of leaks in the "system'. There are too many connections in the "system" one being a swivel connector. If they just replace the motor, the leaks may still cause the new motor to fail again.
    I just ran a line ( just cents) from the Schrader valve to the air bag. ( many here have done this) and it stays at the set pressure for months. It's not hard to do. Contact Joe and Anne Meyer of Squared Away.
    Lew L
    2014 RTS , Circuit Yellow
    Active Member Briorick's Avatar
    Apr 2021
    Southern IL
    Another Spyder rider, on a different forum, had stated that after removing all the necessary Tupperware, it took him approximately 2 1/2 hours to complete his ACS with Bag changeout. And that was also replacing the rear shock.
    2014 RTS Pearl White
    2014 RTS , Pearl White
    Durham,Maine
    Quote Originally Posted by Lew L View Post
    Hi Jack,
    Lew L
    X2
    2012 RTL , Pearl
    Nov 2013
    Oro Valley Arizona
    Hi Jack,
    Lew L
    Well too late now, just took it to Sierra Cycles in Sierra Vista AZ. About 110 miles from here. This is on a RT Limited with the auto level system. If this happens again (I hope not) I will consider doing what you did Lew. Thanks for the post.
    Jack
    2015 BMW R1200R LC
    Durham,Maine
    It really is the cheapest and fastest way to solve a stupid set up!! For what that system dose for you, and the amount you adjust the thing really, it's easier to pump it up to a set pressure and walk away! Good luck Jack!!
    2012 RTL , Pearl
    Faribault, MN
    Jack +1 What Lew and Mikey have said, I changed my '13's system to a straight line from the valve stem under the seat to the top of the bag, haven't had any problems since and I just adjust the pressure before any two up long distance riding then back to my level for normal one up riding. Rarely ever loses pressure, even over months of sitting in my trailer during the winter.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
