Results 26 to 50 of 57
  1. #26
    Active Member BUZZARD II's Avatar
    Dec 2016
    NoVA
    The struts on both the seat and trunk lid started to weaken last year. Mine is a 2016 RT. Of course it wasn't going anywhere due to the Red Dust of Death. So it sat, for six months. I'm not paying CanAm $80. when they knowingly put out defective parts. A stick or door stop is just fine.
  2. #27
    Apr 2014
    full time RV'er on the road. Well we were. Now, 6 months in ThreeRivers Mi and 6 months in Apache
    I think I mentioned this before. Take the "shock" to an RV supply There are all kinds of those used in RVs. I think you might get lucky.
  3. #28
    Active Member linguine's Avatar
    Feb 2023
    AZ
    I use a chop stick cut in half as a prop stick just under the lip of the lid, between the lift hinges.. $0.00; my kind of solution.
    2020 RT Limited , Chalk Gray
  4. #29
    Feb 2021
    Mauston Wisconsin
    I have a 2021 S2S and I don't have a strut. Am I supposed to have one?
  5. #30
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Ironwing View Post
    You have one, you just can't see it. It is on the right side (standing behind the machine) behind and under the hinge. You have to remove the passenger back rest to get to it.
  6. #31
    Active Member BamaJohn's Avatar
    Feb 2015
    Talladega County, Alabama
    My 2020 RT top case strut starting failing intermittently after reading this thread, so somebody on here jinxed me.
    After failing to find a replacement on McMaster-Carr, I ordered a new OEM strut, and when it came I called SUSPA to see if this is the same pressure as the original one, and they said yes. SUSPA was very open and helpful. I asked if they had another strut that was same dimensions with a few more Newtons pressure, and they said Yes...but it's only 2 Newtons more and costs $102, so I installed my $75 OEM strut and it works like it should. No idea how long it'll last, but the original one starting failing at 3 years and 11,000 miles. Now I'll take my official BRP stick out of the top case and store it for the next time the strut fails.
    John B.
    Current ride: 2020 Spyder RT-s Petrol Metallic Blue dark with OEM top case
  7. #32
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    My new to me 21 RT top case appears to not have a ‘shock’ mounted at all. Is this possible? I kind of like the door stop route too…
  8. #33
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Cleg View Post
    Oh, there is one in there behind the passengers backrest on the right side.
    OOOPS! Trick question, 21RT doesn't come with OEM top case.
    If in Doubt, Don't Do It!
  9. #34
    Harrington, Australia
    See post #30 from K80 and post #33 from Knizar, Cleg. I assume you have an RT-L (not just an RT) since you have a top case?
    HeliBars Handlebars
    Kenda Kanine rear.
  10. #35
    Apr 2016
    Albany NY
    Here is an aftermarket trunk replacement, it says seat but those are the trunk part numbers posted in the item information.
    https://www.amazon.com/gp/product/B0...S6F7RLJ5&psc=1
  11. #36
    Apr 2016
    Albany NY
    The amazon support (lift support depot) is much stronger than the BRP support. With a luggage rack you have to push it to close, with the BRP one a gust of wind closed it and I had mine replaced already.
    Much better & cheaper! Mcmastercarr doesn't make one that small to replace it.
  12. #37
    Very Active Member Bangorbob's Avatar
    Jun 2018
    Pahrump NV
    Quote Originally Posted by TIMMB View Post
    Can I safely assume this is for the 2020 + models? Again, this thread has gone between year models and they are different.
    Thanks, Bob
    2005 Roadtrek Chevy 210P
    2020 RT Limited-Chalk White SE6
  13. #38
    Quote Originally Posted by Bangorbob View Post
    Thanks, Bob
    The part number on Amazon is the same as on BRP parts page for 2020+ RT.
  14. #39
    Jun 2018
    Pahrump NV
  15. #40
    Active Member Arachnerds's Avatar
    Mar 2021
    South Dakota
    For the trunk problem, Pierre at canamspyderaccessories.com has a $35 piece that you can add onto the hinge area to hold it up. Pops into place when you lift it up and then you just pop it out when ready to close it.... I don't know that this will work on the trunks of the newer models though. They may need something else.
    https://www.canamspyderaccessories.c...-trunk-holder/
    2020 Spyder RT Limited
  16. #41
    Durham,Maine
    It's not just that, so many times people don't look at the date on the posts and drag old stuff out and answer questions that where asked years before!! Or want to add their problems on the pile, instead of making their own post. That's what makes the world go around, I guess!! I've made that mistake before
    2012 RTL , Pearl
  17. #42
    Oct 2020
    Vinton, IA
    FWIW, I just installed the top case gas shock from the link in post #35 on my 2020 RTL; works fine and was an easy install. I did have to tighten the mounting bracket where the lower end is attached, but had no problems otherwise.
    I may not be the least expensive solution, but is cheaper than a dealer install and I didn't have to deal with down time.
    Thanks!
    2020 Spyder RT Limited; Deep Marsala/Chrome
    Formosa AZ01 165/50/R16's on PPA Recluse wheels up front
    General Altimax RT43 215/60/R15 on factory rear
    Primary exhaust: RLS Cat delete w/ his baffle; secondary, custom built w/ Flowmaster HS2
    Suspension: BajaRon swaybar (highly recommended!), M2 coil-overs, front & rear (also highly recomended!)
    Extra LED lighting and misc. to suit my needs/wants
  18. #43
    Dec 2020
    Hartwell, Ga
    Quote Originally Posted by Arachnerds View Post
    This will not work for the 2020+ models.
  19. #44
    Feb 2023
    AZ
    You have it. It is cleverly hidden by plasticness.
    Ride safe; shiny side up, greasy side down.
    best,
    linguine
  20. #45
    Active Member tntnj's Avatar
    Sep 2015
    JerseyShore
    These work for the seats for the 20-24 RT I may have one for the top case soon for the 20-24 RT , waiting for them to come in
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    2017 F3 LTD (SOLD)
    2017 HD Freewheeler (SOLD)
    2021 RT Base Upper and lower adjustable deflectors , Top case, Signature and lower lights, Baja Ron Bar, Back rest,Fobo TPMS, Garmin 396 , LED Fender lights, Rear LED turn and brake lights, Rear Brake light flasher, Rear Saddle bag LED lights, Battery tender, Lamonster Handle Bar Riser.
  21. #46
    Jan 2019
    Black Fores, Colorado
    I need a new Trunk strut as the old one won't hold lid open. The Can AM part is $79.95. Is there a cheaper place to get one?
    Thank you for your help,
    Gridley
    Last edited by Peter Aawen; 05-20-2024 at 05:34 PM. Reason: Removed Post title after merge - they mess with Searching! ;-)
  22. #47
    Feb 2024
    Tennesse
    I believe that several of the Spyderlovers.com sponsors sell heavy duty struts.
    A couple of searches found "heavy duty" replacement struts/shocks for under US $40.
    racoon
    Middle Tennessee
    2024 CAN-AM Spyder RT Sea-to-Sky - Vegas White Satin
    2023 Honda Ridgeline Sport - Sonic Grey Pearl (aka Baby Blue)
    2024 RT Sea-to-Sky , Vegas White Satin
  23. #48
    Active Member spyderider1's Avatar
    Jan 2018
    Wisconsin
    I just replaced mine. I ordered it from Lamonster Garage. Excellent service, the right part, along with instructions, arrived all in a few short days. (And for far less than $79.95)
    LORD GRANT ME THE SENILITY TO FORGET THE PEOPLE I NEVER LIKED,
    THE GOOD FORTUNE TO RUN INTO THE ONES I DO LIKE,
    AND THE EYE SIGHT TO TELL THE DIFFERENCE.
    2016 Spyder RTS
  24. #49
    Feb 2012
    Spring City,Utah
    I got mine from MacMaster-Carr but I believe LaMonster has them now.
    BTW, if in the future you put the year and model of Spyder in your signature as per the Sticky, it helps us to help you better and make sure we give you the pertinent advice.
    https://www.spyderlovers.com/forums/...-your-Sig-Line!
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  25. #50
    Sep 2023
    Lachute Quebec
    I got mine on amazon, 30 bucks
