Results 1 to 7 of 7
    Jun 2017
    Atlanta
    Cool No Reverse or Signal lights on RT-622 Trailer - is this normal?
    Quick Question for the experts here - I just installed the trailer wiring harness for a 2019 Rt Limited that I purchased from our good friend Pierre at Spyderaccessories. I purchased a used 2013 RT-622 and when I plugged in the trailer, I noticed that there aren't reverse lights or signals lights on the trailer. Is this normal? Do these trailers have the "white" reverse & "yellow" signal lights? Any insight would be appreciated.
    Last edited by Peter Aawen; 09-12-2023 at 08:49 PM. Reason: Expanded title to briefly ask the question... ;-)
    Jan 2021
    Descanso, CA
    Two separate parts to your question:
    (1) how many positions (pins) in the Spyder-to-trailer connector?
    (2) what country code is your trailer? US is combined brake/turn lamp. CAN is separate turn lamp. AUS is CAN with reverse lamp.
    Jun 2017
    Atlanta
    Quote Originally Posted by BertRemington View Post
    (1) how many positions (pins) in the Spyder-to-trailer connector? 4 Pin Connector. US Trailer.
    Thanks 😎😎
    4 Pin Connector. US Trailer. Thanks for the fast response.
    Last edited by Peter Aawen; 09-12-2023 at 08:52 PM. Reason: Merged immediately consecutive posts...
    Mar 2013
    Maumelle, AR
    The 2013 RT622 trailers do not have reverse lights or amber signal lights. The brake/turn/running lights are all the same. That's why you only have a square/flat four pin connector. The 2010 622 did have the separate turn signals and reverse lights and a nine-pin connector. I've owned a 2013 RT622 trailer for nine years.
    2020 RT Limited , Chalk
    May 2017
    Mesa, Arid-Zone-A
    The 622 trailer does not have reverse lights. The 4 pin harness does not support those. You should have turn signals though. The reverse lights on the trailer are for matching appearance only.
    Semper Fi
    Jun 2017
    Atlanta
    Thanks to all !! This information was very helpful.
    Jan 2019
    Hunter Valley NSW Australia
    Quote Originally Posted by Copperman View Post
    Ours here in Australia do come with the same tail-lights as the RT's do and include the Reverse Lights; they are wired up, we just need to find a wire to tap into to make them work.
    Last edited by Peter Aawen; 09-14-2023 at 05:18 AM. Reason: joust; inlcude; ...;-)
    2017 RTL
    2017 RTL , White
