Results 1 to 23 of 23
    Active Member Latrappe's Avatar
    Nov 2022
    Flaxton Queensland Australia
    Default I Had a Close Call! Shock Failure!
    Hello Fellow Spyder lovers.
    I had a very close call last Sunday with the attached Video you will see that I nearly went over the edge of about 800m drop, what the video does not show is me having the handlebars fully to the right as I was bouncing over the road because of image stabilization.
    As you see by the speed, I was travelling around 40KPH about 24 MPH that this should have not happened, but what I found after is dried oil on my left-hand shock absorber, what I believe happened is that I hit bumps in the road as I was turning right to go around the corner causing the Spyder to bounce over the road to the left, giving me a huge scare big enough to have my eye balls bounce off of the helmet visor let alone having to change my diapers and have 1/2 a dozen beers.
    What I have also noticed is previously is going around right hand twisties the nanny is starting to kick in where it has never done before, that in itself is a lesson learnt, pay attention your bike is telling you something, I am under the belief it is the left shock failing again you won't see the bike drop to the left as I commit to the corner and yes I do lean forward toward the direction I turn and Push Pull.
    Apart from having a bruised Ego everything is ok I also think if it was not for BAJA Rons sway bar it probably would have been worse yes, I know we all have moments whether it be inattention or loss of concentration but read the road and if you bike is trying to tell you something like doing things it has never done before have a look.
    https://www.youtube.com/watch?v=xtnzyIRoufA
    2019 Can Am Spyder F3S
    ICSI Ride Hand Brake Kit as my right leg and foot does not work that well due to MS
    The Ultimate F3 Floorboard
    Baja Ron Sway Bar
    Shad Saddle Bags
    Lamonster F3 PACKRACK
    SHAD 58X in Carbon finish - Expandable TOP Case
    Pedal Box
    IPS Belt Tensioner and Handlebar Riser from Lamonster
    K&N air filter
    INNOVV K5
    Wilbers Nite Line Shocks
    RLS Cat Delete
    Floating Rotors with EBC Brakes for the front
    I am now broke
    I Should mention the Boss has a 900 Ryker Ralli next to my bike
    2018 F3S , Monolith Black
    Northern Kalifornia
    Looks like you over shot your turn.
    Bossier LoUiSiAna
    Glad are ok & able to share.(now sarcastically yank if you will ) If you were driving on the Right side of roadbeen avoidable all together
    Does look like some nice riding
    Durham,Maine
    There are all kinds of stuff I would like to say about this video, but I won't, but, what I will say is I am glad for you that you were only going the speed you were!!! Years ago, when my daughter was growing up and I gave her, her first sled, I would tell her, don't over drive your vision, or your equipment. I always tried to set up her sleds to the best of my ability, the rest was up to her judgment. Know your equipment and its limitation's. Be safe!!!!
    2012 RTL , Pearl
    Nov 2022
    I hear you load and clear Mikey, here is another clip same hill different day and I went up even quicker then.
    https://www.youtube.com/watch?v=SoWbe0QR9EA
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
    I found it interesting watching the first video in that you had forewarned us of your speed, because I don't watch many of them and had I not known how fast you were going I would have assumed a higher speed. As the great Sterling Moss said, "Better to go into a corner slow and come out fast than to go in fast and come out dead."
    Northern Kalifornia
    Don't forget he's down under. They all drive on the wrong side of the road down there. They can't help it those are the rules they must follow. Yes, glad he ok.
    Northern Kalifornia
    Quote Originally Posted by Latrappe View Post
    Much, much safer! Good video, but I'd like to see a roo or two.
    Harrington, Australia
    The roos are much too smart to come out in daylight, 2Dogs. You might see them coming. Once they have made up their mind to commit suicide, they wait until dusk (or night), when they are much harder to see. They then get out their satellite photography maps and find an area where the tall grass has been allowed to grow to 5 feet, and settle down to wait. As soon as they see you coming, they hold their breath so as not to give their position away, use their protractor and calculator to determine the most damaging place to land in front of you, and time their single leap to perfection to ensure you have no time to react. Cunning little devils……well, maybe not so little…some of them are 6’ tall and built like Arnie
    HeliBars Handlebars
    Kenda Kanine rear.
    Northern Kalifornia
    The dam deer up here seem to do the same thing. The only way you can safely avoid them is to slow the hell down and look for the reflection of your headlights from their eyes otherwise you can't see them. Sometimes cars can run interference for you and hit them before you get to them.
    Bossier LoUiSiAna
    Hence : (now sarcastically yank if you will )
    Northern Kalifornia
    Always wondered if it was a little spooky for you folks when people from the U.S. come down to visit and rent cars to drive around in. I know I'd be scared because of the kind of drivers we have up here. That isn't being sarcastic, that's just the truth of it.
    Sep 2018
    Australia
    What's that noise you hear during the out of control bit??
    Quote Originally Posted by Cobwebs View Post
    That's the ABS/Nanny doing its thing - the failed shock set him up perfectly for a launch off the edge of the road followed by a loooong drop
    Only his quick thinking, reaction, and the Nanny intervened and together, managed to foil that little plan!
    You gotta be lucky sometimes, even with some Divine Intervention... but it sure helps to be alert and have a Nanny that does work on your side too!
    Nov 2022
    Apart from the ABS and Nanny, I think one of the noises was me dirtying my pants and no, I have not been out on it since been raining cats and dogs here (with a few drop bears and killer kangaroo's) since Monday so most of the exit roads are flooded.
    I also admit having a few stiff drinks after as well.
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
    Durham,Maine
    So, let's get back to the shock! Was it blowen out or was the oil you say on the shock just the small film you always see on the shock stem? How old are they?
    2012 RTL , Pearl
    Nov 2022
    Hi, Mikey the oil residue on the shock not the stem, they are the original shocks on the bike being 2018 model which I bought in 2019, age wise 5 years but how old were the shocks before they put them on the bike??
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
    Active Member Texas Al's Avatar
    Jun 2017
    Azle TX
    Glad no-one got hurt. But bad things happen when you drive on the wrong side of the road!! ha ha
    2021 900 Ace , Black & Gold
    Nov 2022
    Hello Guys,
    A while back I put up this Vlog about my close call and mentioned that my left front shock was on the way out, I ended up replacing the shocks with Wilbers, here's a picture of the left front. The right front was clean as...
    I will add more shots later.
    Last edited by Peter Aawen; 04-17-2024 at 09:41 PM. Reason: Moved Post title after merge - they mess with Searching; & we do like to try & keep all the related stuff in one thread. ;-)
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
    Oct 2020
    Arizona
    So having had steering issues recently! Did you actually have the steering turned for a tighter turn then going off the highside of the corner, or did the steering lock and not want to turn more to the right???? Which is a bit similar to the issues I was having. My issue more or less repeated a handful + of times. I had the feeling of binding in the steering. I am not sure what caused it! I replaced the right hand lower ball joint, unplugged the cable at the DPS and sprayed both sides for the connection with contact cleaner and then replace the other side lower ball joint. Problem has not returned.
    What caught my attention was you did not stop and look things over, despite "giving me a huge scare" but continued to push on!
    Here is a link to my thread. https://www.spyderlovers.com/forums/...nny-takes-over
    What I was having occurred so quickly that I had a bit of a problem replaying what happened. Issue went away as quickly as it occurred. I rode very carefully for a couple weeks while working through the issues I was having. Luckily none of the times my steering seem to lock caused me to run off the road, or I would have parked it.
    I replayed what happen in the early times in my mind over and over again, to come to the conclusion that the DPS was failing and locking up or something in the steering was binding.
    I hope you get to the bottom of your issue, however I do not think the shock was your issue. Watching the video repeatedly, if the camera is mounted to the trike, it appears that the trike just headed straight to the side of the road, which is what my steering lock up would have caused. Steering was hard over or steering locked and not letting you turn more????
    Dec 2020
    Down South
    Poopy pants for sure. Glad you made it through. I probably would have said my prayers, took some vitamins, and walked home.
    A lot of luck, divine intervention, skill, and technology can be a life saver
    '20 RT Chalk Metallic
    Oct 2021
    Ontario
    Some days you are "Good."
    Some days you are "Lucky".
    Some days you are "Good and Lucky"
    Glad you came out OK
    Nov 2022
    Hello guys, I have now got new shocks the is riding better than when it was new, I also put a RLS cat delete on (now it no longer sounds like a sewing machine) and fitted floating rotors.
    Now I have to wait for this wet weather to disappear, then I can get some wind therapy - not that I mind riding when it is wet!
    Here is a Photo of the offending shock
    Baja Ron Sway Bar
    Shad Saddle Bags
    Pedal Box
    K&N air filter
    INNOVV K5
    RLS Cat Delete
    I am now broke
