Results 1 to 17 of 17
    Jan 2024
    Texas
    Question 2012-2019: highway pegs that do not interfere with breakaway floorboard?
    I'm interesting in adding highway pegs to my 2019 RTL that would be positioned above/beyond the little black wind deflectors in front of the floorboards. The pegs I'm finding all attach to the bottom of the OEM floorboards, and the comment section for one on Amazon seems to indicate that the there's no longer enough clearance for the breakaway function of the floorboard to still work if you have to stomp on the brake in an emergency.
    The slingmods guy gave me a weird answer about theirs, so I'm not completely sure he understood the question. (I think he thought I was concerned about braking in general.)
    "Here is a picture of the pegs on the RT. As you can see they are spaced well away from the other components, enough that unless one had particularly large feet they would not interfere with one another. "
    Do you guys have any experince and input?
    Amazon: https://a.co/d/9fNCaIM
    Question/comment I'm worried about: (see attached screenshot)
    Slingmods: https://www.slingmods.com/canam-spyd...tras?vehicle=1
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener
    Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire
    Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps
    KOTT Grill covers
    LED Headlights + LED Foglights
    High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT
    Show Chrome gas shock for rear trunk
    Foam Grips
    Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system
    Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock
    Oct 2021
    TX
    I have the NBV highway pegs from Lamonster. Might be what you are looking for.
    2019 RTL
    2019 RTL , Blue
    Quote Originally Posted by Allen42 View Post
    I designed and made sturdy metal brackets that were fitted into those wind wings ( so they were invisible )..... I could actually stand on them without issues ( 175 lbs. ) .......Mike
    Nov 2013
    Central Texas
    My advice would be to not get the pegs from slingmods. I have them and don't really like them. There is not very much adjustment, I can't get them far enough forward, so I get cramps in my hips. They attach to the floorboards, which is really not an optimal place to mount them. I might give the Lamonster NBV's a try. It's only money.
    Oct 2020
    Arizona
    Here is a comparison:
    Champagne AKA hooker = floorboard mounted
    and
    Asphalt Grey AKA hookie = frame mounted
    and
    The mod I did so the right hand floorboard could still do the breakaway function. The floorboard once are a bit more forward.
    Both sets are available. I have a medical situation that causing me to not use the foot pegs.
    Jan 2024
    Texas
    Quote Originally Posted by Snoking1127 View Post
    and
    and
    Very cool, and you're quite handy. I like the idea of the frame mounted ones, as long as they are sturdy enough.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Clinton, MS
    Have you looked at Lamonster Garage yet? You will find exactly what you want.
    2019 RTL Phoenix Orange
    Sep 2016
    Chillicothe, Oh.
    I have a base model RT which has foot pegs instead of floorboards. Lamonster Garage has a set of pegs for my bike and they don't mount to the boards, but behind the black deflectors. Perhaps they will do what you want.
    PXL_20240228_233554049.MP.jpg PXL_20240228_233601761.jpg PXL_20240228_233605496.jpg
    2015 RT , Black
    Jul 2023
    Chesterfield SC
    I have the floating forward floorboards on my 2011 RT. Really like them and easy install.
    Leon
    2011 Can AM RT-S SE5 Red
    Feb 2017
    I added the Lamonster NBV (No Bad Vibes) highway pegs and am very happy with them. Good product, relatively easy to install and sit just above the wind deflectors you spoke of.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    I have a set of the Slingmods had back surgery can't use them willing to sell if interested.
    2016 RT Limited Orbital Blue. Ultimate seat
    Bajaron swaybar,PV3 with BLR custom Tune
    Farrod front car tires p165/65/15
    Led headlights and fog lights
    Showchrome windshield.
    Two Brothers Muffler and cat delete pipe.
    Jan 2024
    Texas
    Quote Originally Posted by helton61 View Post
    I'm looking at Snoking's set, but if that falls through, I'll be in touch. Thanks!
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Faribault, MN
    I bought the CanAMSpyderAccessories Floating "pegs" from Pierre, love them.
    They're very low observable, protect the rain deflectors, don't affect the emergency break-away floorboard.
    And at 240lbs myself, they support my weight and feet just fine.
    https://www.canamspyderaccessories.c...th-black-edge/
    Last edited by Peter Aawen; 03-01-2024 at 03:05 AM. Reason: Fixed attach display ;-)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jan 2024
    Texas
    These look like a good option too, thanks for the pics.
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
    Mar 2008
    Hesston, PA
    I also have these on our 2014 RTS...Very Pleased...larryd
    Active Member Partzman23's Avatar
    Jul 2020
    Sikeston ,Missouri
    I too have these on my 17RTL. I love them.
    2017 RTL Asphalt Grey Metallic Chrome
    2017 RTL , Asphalt Grey Mettalic
    Jan 2024
    Texas
    I just wanted to close this out with a good word for user Snoking1127. We made a deal on his pegs, and he quickly shipped exactly what he said he would. He even went to the trouble of labeling parts, sending a link to an install video, providing a tracking number, etc.
    He's a good guy, and can be trusted!
    Highway pegs
    KOTT Grill covers
    Pedal Box+ w/BT
    Foam Grips
    Red Rim Covers
