2024 S2S won't go into Reverse gear - anyone else? What's the fix?
With the Spyder Running, Foot on the Brake, roll the Throttle Forward as far as it will go, Left side control pull the Down Shift lever.
Seems to be a common issue. I also have a 2024 STS and the same thing happened to me last month. It started by not engaging once out of 4-5 times and within a week it was a no go at all. The dealer changed the “reverse actuator switch” under warranty. Took a week including ordering the part.
That's what I was just going to say, if I had a new bike, it would be going back to the shop if there was any chance of warranty work! What is the warranty on the new iron now?
On my 7th time in for reverse problem. Reverse actuator replacement did not fix problem. Hopefully for you it takes care of your problem. Been dealing with this since last year in June. Got bike in April.
I have a 2024 sea to sky won't go into reverse. Anyone have this problem and what was the fix? Tks Gary M.
My 2020 spyder RT had same issue plus the parking brake would not disengage either. My mechanic checked the reverse actuator, and noticed that the housing plastic plate was smashed and bent, preventing the actuator to work the way it is intended. It is fixed now.
