Access to gas cap.
Casher50
What would you do if you needed gas and the seat on my RT would not open? Is there a way to manually access the gas cap?
You CAN rig up an alternative method to access it:
attachment.php
You could use a coat hanger to pull the release on the right side, remove the part from the seat that goes into the latch, put a wire from the latch to somewhere near the front of the seat ( you could do this with the frunk as well ) or get a seat with a gas door or put a gas door on your current seat.
Depends....
Is the latch to the seat broken, stuck, don't have the key. I always carry two keys to avoid the misplaced key issue. I turn the key in both directions in case of a memory lapse, I do the press down pull up if stuck and finally find a wire to release the latch. The secondary pull is a good ideal if this is a common problem but it should not be and may just need some adjustments to make it right...:thumbup:
I always keep an un-chipped dummy-key in the glovebox. It gives me access to where I've hidden the REAL key... :thumbup:
:lecturef_smilie: Removing the seat lock COULD be a problem...
...If you ever planned to use the "unusable" hook under the seat for hanging your helmet. :roflblack:
