Air Pump Replacement (HELP)
Frank G
Looking for information on witch panels to remove to replace the Air Pump. Removed the right side panels and found the air pump to be in the center of the frame behind the fuel tank. Not sure on how to proceed. Looking for help.
there is a thread on this subject if fact it was being posted to just yesterday or the day before. Do a search for compressor replacement or look under forums RT shop talk and just scroll thru. Any way you do have to remove the entire rear luggage carried,it is a one piece unit and also the fender and spash guard. It is a 2 man job as I remember the posts. It is worth finding as he has very good pictures and explanations.
Found it http://www.spyderlovers.com/forums/...eplacing-stock-air-compressor-with-Viair-097c
Thank you all for steering me in the right direction. Ordered the Viair 097c Pump and the green manual for additional support.
This site is the greatest! :yes::yes::yes:
