I don't know if it's proper to place this thread here. Speaking of wheel alignments, would a steering stabilizer be the icing on the cake after a laser alignment is done properly. This looks like a good idea to me though.
https://www.youtube.com/watch?v=Cqd_SEN-phE&ab_channel=BiLLRamseyer
The OP was talking about his Ryker, and the alignment issues apply to them as well as to Spyders,
so yep, I reckon this thread is fine here. :thumbup:
As for the steering stabiliser idea,
it's not applicable at all to any Spyder, cos they all have Power Steering :yes:
And while it might be a great gimmick that'll lighten the wallets of
some Ryker Owners, it's
not really going to be a great idea for any Ryker that
already has an alignment issue, cos at best all it'll do is mask the issues completely until the tires scrub enough to be bloody obvious, altho I guess there's a chance it might stop the Ryker Ryder feeling
some of the steering feedback while still allowing all the misalignment wandering, scrubbing, & tire wear etc; while at worst it'll stop the top end of the steering from responding to
anything in the way of road feedback but still leave the two front wheels either scrubbing out or still wobbling away & pounding the crap outta the tie rod ends, suspension, & steering components etc, and possibly it'll even make any handling &/or control issues
worse... :shocked: . And if you get or have already had your Ryker aligned properly by someone like cptjam from Squared Away
then you won't need a steering stabiliser anyway cos that will sort all the erratic handling issues
PROPERLY - as for getting the alignment done, see cptjam's post above or any of his alignment threads - if your alignment is OK & no correction is necessary, he'll show you & it's free... but if not & it needs some correction, he'll show you & then he'll fix it for you!
hyea:
There again, if you wanta whack 35" dia Off Road tires onto your Ryker, maybe stuff a low range transfer case in there between the CVT & the drive shaft somewhere, and give it a dirty great lift to turn your Ryker into a Rock Crawler or maybe just add long travel suspension & turn it into a Course Runner, then maybe a steering stabiliser might be a good idea?!? :dontknow: Or not....
Just Sayin' :thumbup:
