Adventurer
This is regarding my 2021 RTL (Sea to Sky). I searched but no luck using the search function with multiple words.
Recently my instrument cluster would not come on when I turned the key to on position. Nor would the starter button do anything. It was like the battery was completely dead, but all the lights came on and the horn worked. Started checking fuses and noticed a lot of corrosion inside the JCase style fuses and two of them had shorted (main control jcase #4 and DPS jcase #3 in the left fuse box) due to the extensive corrosion. I replaced the bad fuses and all is well for the time being. Has anyone else encountered this problem and if so, what is the solution to prevent it from happening again.
I’m thinking about disconnecting the battery, pulling all the fuses and spraying the terminals down with battery terminal cleaner, cleaning with a small brush and compressed air. Letting it dry thoroughly before reassembling. Any one see any issues with this approach.
I’d really like to know the root cause, maybe riding in the rain? I always hand wash and never use a power washer or commercial car wash so wouldn’t think that should be a problem. Any input?
