DriftersWay
does anyone have info about the kenda kanine tires?
Thanks
Thanks
They are hard to get as they are better then the OEM Kenda. I wouldn’t use a car tires as I don’t ride a 3-4000lb car but a 1400lb motorcycle. Major difference in tire rubber.
https://powersports.kendatire.com/en-us/find-a-tire/motorcyclescooter/street/kanine/
The fact that it is a KENDA is all the information I needed to avoid the brand. I went with Vredestein Quattro because they stick the best in all temps & wet.
Be nice guys and gals. :roflblack:
I am running K-9's on my 2019. Had them for over a year now. I see no issues or problems. Not a long enough test for longevity yet.
I also do not have a problem with Kenda OEM's. 20K for fronts and 15K for rear tires, average. Been through a lot of sets in almost 200K miles on 7 assorted Spyders. :bowdown:
Asbestos suit: ON :yes:
Considering the Hundred's and hundred's of comments / wear reports from other members here .... wouldn't you admit Your experience with the Kenda products are Quite unusual ( to say the least ) ?????? .... Personally I have been critical of the Kenda's ... but have always said " with Good alignment " front tire is decent as far as Wear is concerned ..... Mike :thumbup:
Enter 'Kanine' in the search box up in the top right of this screen; tick the drop down box that says 'Search Titles Only'; then click on the little magnifying glass!hyea:
Choose whatever you want to read out of the numerous threads that the search request above will return until you're satisfied that you know all you want to know about them! :thumbup:
Here's one I prepared earlier, it may or may not work for you:
https://www.spyderlovers.com/forums/search.php?searchid=3181343
Enjoy! :cheers:
Ps: the Kenda Kanine is basically an OE Spec Kenda clone constructed with a longer wearing tread compound - personally, I wouldn't use them to keep the important bits of MY Spyder off the road, let alone in any situation where MY safety or that of any of my loved ones relied upon them.... But then again, some have found they've performed reasonably well for them/their ryding... :dontknow:
Thanks
If it was a "one time" experience with them I would say "fluke." Since the only "outlier" in the bunch was the OEM's that came with the 2014 RT's (a new rubber compound). That rear tire gave me only 8,900 miles before it went bald in the center. I drive very conservatively, keep my speeds at the low end of the speed limit range, no burn outs, etc. One other thing, I keep my rear tires inflated at 26 #. This allows for some expansion and less "balooning" of the tires.
I did try auto tires (Federal) one time when I first moved to AR in 2019. Only kept that bike (2014) for one more year and traded. No chance for a longevity check. Now, neither of my mechanics offer real auto tires so I was stuck the last go around with OEM or K9. And yes, I know that "J" rims are considered auto tires. :bowdown:
I like being the "odd man out" sometimes. But, my information on the OEM Kenda's and K9's are my actual experience. Seven Spyders/ almost 200K miles. :dontknow: :bowdown:
I post my experience for general information to the site. There seems to be a group of you that put us "crapenda" users in a "special" category. That suits me, and works for me, but I don't like seeing the Kenda users demeaned, intentionally or not.
My position here is as a general site member with a personal opinion. No mod stuff from me is going to be involved with this post or thread.
Sorry Flamewinger, but if you're running a Kenda of any sort that fits the OE Rims on your Spyder, then you ARE using a car tire- just a lightly constructed one that comes out of a factory that has pretty shoddy quality control and not a great reputation! :lecturef_smilie:
Rim profiles do not a car tire make. There is a heck of a lot more to it. Just because car tires fit doesn't mean it is the best and safest option. It just may be the longest wearing.
