Anyone installed a Sirius XM radio receiver on their RT? Any hints?
MCole
Has anyone installed a Sirius XM receiver/player on their Spyder RT? I would like to install one on my S2S.
Why don't you just add your smartphone to the Sirius plan and Bluetooth to helmet speakers? Might be able to put phone in storage and use data cables to spyder speakers
I have IHeart and SiriusXM apps on my Iphone. They blue tooth nicely to my 2022 S2S, with clear audio. When/where service is spotty, I have a trusty IPod in reserve :)
I also use the XM app on my phone along with Pandora and MP3 files. Bluetooth works great and was easy to set up! One account works everywhere I want it
As others have said, the app should work in most instances.
If you're wanting to use something that doesn't involve the phone, then something like the kit I have linked below should do the trick.
I have used a "portable" kit for years (10+) in various vehicles (currently in my '99 full-sized van), and it's always worked great.
https://www.amazon.com/Satellite-Motorcycle-Installation-Commander-Adjustable/dp/B09JL8WSRT/ref=sr_1_8?crid=X003JQFEPQNI&keywords=siriusxm+motorcycle&qid=1696852916&sprefix=siriusxm+for+moto%2Caps%2C1100&sr=8-8&ufe=app_do%3Aamzn1.fos.f5122f16-c3e8-4386-bf32-63e904010ad0
--Exco
I installed an XM receiver on my '20 RT. I connected the XM's audio out to the AUX IN plug and used the 5v power from the USB plug. I ran the antenna under the tupperware to the back and glued it to the right top (opposite the RT antenna). If it rains, I cover it with a ziplock baggy.
I use a Siriusxm stratus7 on my S2S. Mounted it on top of the glove box door and plugged it in in the glove box. Mounted the antenna on the dash under the windshield. Had to buy a USB cord to power it. They make one specially for xm receivers.
I put an Onyx EZ into the glove box of my `14 RT ..... removed the OEM plug from the rear trunk and stripped it from the harness .... I then ran the cable up the right side ( under tupperware ) and drilled a hole in the right side of glovebox ... mounted ithe plug and made a sheet metal holder for the Onyx..... I have pics of it in an Album .... I don't know how much room you have in your glovebox , so it may or may not fit ..... I can change stations on the fly if I have to ....good luck ...Mike :thumbup:
