Anyone removed the rear Top box/pannier assembly (Aust up to 2018 RT models) is the t/light plug the same as the trailer plug?
askitee
If you have, do you happen to know if the plug you disconnect that supplies power to the tail lights etc is the same plug where BRP has us insert the trailer module?
Background
When I bought the towbar in 2019 it came with the BRP Relay. To install I needed to separate a plug under the seat and insert the relay between these connectors. The relay connector facilitated 12V power, earth, Brake, Tail and Indicators but not reversing lights. I am hoping that the Reverse lights in the rear may be in this connector we have to separate.
