Battery Tender On & Green but not charged
nealperkins
I decided to go out for the season's first ride, the battery tender was showing GREEN but, there was an insufficient charge to turn the engine over. Weird. That's never happened on any bike. Has this ever happened to you? If so, what was the cause? BTW, the battery connections seem tight.
Thanks!
Battery Tender
Did you check the battery voltage for 12.8 volts? :coffee: I guessing that you did all the look and wiggle tests. :f_spider: Maybe in need of a NEW Battery. I would have the Battery LOAD Tested FIRST.:thumbup:
Interesting....🤔
Need to check the output on the battery tender. Then need to load check the battery after a full charge. Sometimes there is a surface charge indicating that all is well till you put a load on it. Lights will come on and all fine till you hit the starter button. That, of course, is if it is the battery. Otherwise you would have to check other parts...:dontknow:
Yes this happened to me, and as it turns out it was the charger/tender, which showed a green light. As a result the battery was not able to start the spyder. I then took the battery to my dealer, and they placed the battery on their charger all night long. The next day they said the battery was at 12.9 volts, and good enough to start the spyder. Long story short, it wasn't good enough to start the spyder; like Chupaca said, it was probably only a surface charge. In my case, I replaced both the Odyssey battery, and charger; the battery was free, and the charger discounted even though I was a year or two past warranty on the battery, and many years past warranty on the charger.
That makes sense. I'll check that out. After a two hour ride the battery said it was 85% charged. Does that sound about right?
I find with a Battery Tender, if the battery is beyond the ability to take a charge the BT defaults to the green light.
Battery Tender
Not sure how you are doing your testing. A test to see if the 'Tender' is putting out a charge, would be Check the battery voltage while the Tender is saying/showing it is charging. The Voltage should be 13 to 15 volts.:thumbup: Need a good Volt meter to check this Voltage. :spyder:
That is the way it was done, at the place that actually sold Odyssey batteries and chargers. In my case it is the Odyssey charger that I use.
A dead cell will show that indication!
AJ
Thanks!
This just happened to me with my 2017 F3T. Battery would indicate a full charge but not be charged. Checked all the connections, all seemed fine. Took it into dealer and it was determined that it was a bad battery. Replaced under warranty.
No.
Where did you find that talking battery ?? ;)
Let it sit for a few hours and see what happens.
Likely that battery is past it's useful life.
