Belt Replacement Help
aracrash
I am about to replace my belt while I am changing out the tire. Does anybody have advice or tips? Seems straight forward.
That it is....
If your there for the tire makes sense to do the belt if it needs one. Check wheel bearings brakes and disc as well while your at it. :thumbup:
It is. No worries. We have done several. When reassembling, leave bolts loose until all are started. Then tighten and torque. If you get stuck, call. Number below. I’ll walk you thru it. Joe
