Get the smooth spyder belt tensioner. Fixed.
I also run about 180.... You will be amazed at the difference.
I feel like I've read somewhere here that BRP released new belt tensions? TSB? Anybody have a link or know what they should be? Dealer doing first service minus oil change and I would love to get rid of that vibration at 70ish mph!
I installed the smooth Spyder tensioner and still get to much vibs. It's better though. I have it set at 14. Do I need to loosen the belt.
I installed the SmoothSpyder last week, initially setting the tension at just short of 11 pounds. The vibration was gone at 73 mph, but had some at 50 mph, and some vibration at deceleration. Much better, since the 73 mph range is much more important to me for cruising. I then set the tensioner at 12, and it was worse. Then dialed back to 10 and have ridden about 600 miles since then, and I have a little vibration in the 79 mph range. Much, much better.
I will probably experiment some more eventually but for now I'm delighted with the results.
Jim was super helpful and responsive, and was also very patient with me.
-Bill
These are the numbers I've gone by that BajaRon had posted.
Is this just a guess or a proven fact from BRP? My service manual states 1050N +/- 150N.There are many versions of this / His chart..........I don't think that chart is the current best settings.............I believe they have been lowered..........Mike [emoji106]
Sent ya a PM. 630N is around 141 pounds, that seems low to me? Who knows :dontknow: What is everybody else running? Tension on ground or air?
There are many versions of this / His chart..........I don't think that chart is the current best settings.............I believe they have been lowered..........Mike :thumbup:
Awesome. Ron what would you suggest?
I am not sure in what aspect of this process you are asking about.
With the 2008-2012 Spyders and their lower belt tension specs., I suggest checking tension with the Spyder on the ground. As you can see there is quite a wide spread in acceptable tension. Checking with the Spyder on the ground will tell you if you are in spec or not. If not you will have to raise the Spyder anyway and use the 'Wheel off the Ground' numbers. Be aware that when you finally get the belt where you want it, tightening the axle bolt will change the tension (probably increase) somewhat. Usually not enough to worry about. Especially if you're in the middle of the tension spectrum.
For the later models with higher tension requirements you have to raise the Spyder because 'Wheel on the Ground' specs exceed the Krikit's ability. If you are using another form of belt tension gauge that will measure beyond 300 lbs., then you could do the conversion to the 'Wheel Elevated' numbers and do this with the wheel on the ground.
Every Spyder (and rider for that matter) are different in respect to vibration. My Spyder belt vibrates and it doesn't bother me. This same vibration might drive someone else crazy. When, where, and how much vibration you get is pretty much infinitely variable. Sometimes adjusting the belt just moves the vibration to another speed. But you can experiment with belt tension (within specs for your Spyder) to find your 'Sweet Spot'.
Remember, when you adjust belt tension it usually takes 100 miles or so for the belt to settle in to it's new environment. So give it a chance to do so before trying again. You might be surprised.
In the final analysis, you will need an aftermarket belt tensioner to get the greatest reduction in vibration possible.
Sorry was talking about poundage. All great info. Thank you! I'm looking to move the vibration to a higher speed past the highway cruising speed of 70-75mph.
