Biosafena
I have a 2012 RT Ltd. with just over 3000 miles. It has always had a low frequency vibration in the front end. Just enough that would make you hands and arms numb after a while. I found that one wheel has 1/2 oz. of weights on it, but the other wheel has almost 3 oz. of weights on it. While I had the wheels of for a good cleaning, I decided that I would have he balance checked and see if I could address the vibration. The wheel with the 1/2 oz. on it was spot on and needed nothing. The wheel with the 3 oz. showed that it needed another 1/2 oz. added. But here is where it got good....when spinning the wheel and tire we can see both wobbling about 3/8". Thinking that maybe we didn't have it chucked up correctly on the balancer, we tried again and again with the same results. Understanding that we are only doing a static balance rather than a dynamic balance to allow for weights only on the inside of he wheel. The tread wear looks pretty much the same as the other side. Has anyone else experienced a wheel this wobbly from the factory?? I have not hit a curb or pothole or any other objects. The bike drives straight and the steering is tight. I called the dealer and he wanted me to bring the whole bike in. I choked on that with the weather we are having and told him that the bike itself is fine, the problem seems to be only with the wheel (not even sure there is a problem with the tire). He finally said to just drop off the wheel and tire and he will see if BRP will do anything. Didn't sound too positive. Keeping my fingers crossed.
Sent from the corner of walk and don't walk....
