Brake Fluid Reservoir Caps
Cruzr Joe
Maintenance/Safety issue on Brake Fluid Reservoir caps
Be sure that the Brake Fluid caps on your Spyder are on correctly, the small spout looking part should be facing the rear of your Spyder or else it will leak brake fluid, if your brake reservoir looks like this you are in good shape, if it is black and dingy looking, then you may have the caps on wrong or loose. be sure to clean the area surrounding the brake fluid caps prior to removing them so that no trash/contaminants get into your brake fluid and be sure to refill your reservoir with "DOT 4" brake fluid.
Merry Christmas to all
Cruzr Joe
attachment.php
