Brake Light Wire Color
I have a 2012 RSS and need to know which wire is the brake light. I seen a post stating it was white however, I wanted to know if it was the same for all spyders so, I am not tapping into the wrong wire.
Thanks in advance.
Rt Rear Turn Signal = Brown/Yellow
Lf Rear Turn Signal = Gray/Pink
Running Lights = Orange
Brake Lights = White
Ground = Black
The above was for 2009 RS. I have a 2018 F3-T, and my brake light wire is also WHITE. You make the call. I do know that HONDA's wire colors are the same through the same model line.
Al in Kazoo
Ground = Black
Al in Kazoo
Thank you for the information.
