Brake pedal adjust
Habib
2017 F3S, I want to adjust the brake pedal so that it is not at a 45* to the foot pedal. Can it be adjusted independently from the foot peg? It needs to rotate forward.
Thanks.
Thanks.
There is an adjustment for it at the master cylinder. You can get to it near the rear of the brake rod and then look up a bit. It is the jam nut on the threaded pushrod going into the master....
Do a search for the couple of long threads on this. Some of us have have altered the connection ( very easy) to put the pedal in a lower position. My wife loved the mod.
